J****mes
Ten Common problems in PCB Design
3370
10
Oct 18.2018, 17:35:19
I. overlap of pads.
1. The overlap of the pads (except the pads on the surface) means that the overlap of the holes in the drilling process will cause the drill bit to break because of drilling many times in one place, resulting in the damage of the holes.
2, two holes overlap in the multilayer board, such as one hole position is the isolation disk, the other hole position is the connection disc (the flower soldering pad), after drawing the negative in this way, it appears as the isolation disk, which causes the scrap.
II. Abuse of graphics.
1, in some graphics layer to do some useless line, was originally a four-layer board but designed more than five layers of lines, so that cause misunderstanding.
2. It is easy to design. Take Protel software as an example, Board layer is used to draw the line of every layer, and Board layer is used to mark the line. In this way, when the light drawing data is carried out, because the Board layer is not selected, the line is missed and the circuit is broken. Or it may be short-circuited by selecting the marking lines for the Board layer, so the graphic layer is designed to be complete and clear.
3. Disobeying the conventional design, such as component surface design in Bottom layer, welding surface design in Top, cause inconvenience.
III. Misplacing of characters.
1. The character cap pad SMD solder piece brings inconvenience to the on-off test of PCB and the welding of components.
2, the character design is too small, resulting in the difficulties of screen printing, too large overlapping characters, it is difficult to distinguish.
Setting of single side Pad Aperture.
1. One-sided pads are usually not drilled. If the holes need to be marked, their aperture should be designed to be zero. If a number is designed, then the coordinates of the hole appear at this location when the borehole data is generated, and there is a problem.
2. Single-sided pads should be marked with special marks if the holes are drilled.
V. draw pads with padding blocks.
The pads drawn with pads can pass the DRC inspection when the circuit is designed, but can not be used for machining, because such pads can not directly generate the solder resistance data, and when the flux is applied, the filler area will be covered by the flux. It is difficult to weld and assemble the device.
6. The electric strata are both flowered pads and wired lines.
Because the power source is designed in the form of solder pads, the layer is the opposite of the actual image on the printed board, and all connections are isolating lines, which the designer should be well aware of. By the way, care should be taken when drawing several sets of power sources or isolation lines for several types of ground, not to leave a gap, short circuit two sets of power sources, or block the area of the connection (so that one set of power sources is separated).
7. The definition of processing level is not clear.
1. The single side board design is in the TOP layer, if does not add the explanation positive and negative to do, perhaps makes the board to install the device but not to be able to weld.
2, for example, a four-layer board design using TOPmid1, mid2 bottom four-layer, but processing is not placed in this order, which requires explanation.
There are too many padding blocks in the design or the padding blocks are filled with very thin lines.
1. The light painting data is lost, and the light painting data is not complete.
2. Because the fill block is drawn by a line in the light painting data processing, so the amount of light painting data is quite large, which increases the difficulty of data processing.
The pad of the surface mount device is too short.
This is for on-off testing. For too dense a surface mount device, the spacing between the two pins is fairly small and the pads are very thin. The pin must be installed in a staggered position (left and right), such as the pad design is too short. Although does not affect the device installment, but can cause the test needle not to open incorrectly.
X. the spacing of large area grids is too small.
The edge of the grid line is too small (less than 0.3mm). In the process of PCB manufacturing, there are many broken film attached to the board after the image is displayed, which leads to the broken line in the PCB manufacturing process. The result of the paper is as follows: (1) the edge of the grid line is too small (less than the edge of the line).
I am not a Original creator. I copy it from this company PCBGOGO who is the best PCB prototye in china.
This is not a spam,just a share.
So pls save it , it is helpful the PCB beginers
- Comments(10)
L****rry
Apr 11.2024, 18:45:36
Appreciate you sharing these insights from PCBGOGO. Recognizing these common PCB design pitfalls early on can help beginners navigate their projects more effectively ensuring smoother processes and better outcomes.
Affordable Residential Painting Services
Apr 01.2024, 09:49:44
Hello Neighbor Wiring errors: Comparative differences between design and wiring are the main cause of errors in the final stages of PCB design. So some things need to be re-examined.
For example: device size, quality of vias, pad size and review level. In short, it needs to be carefully checked against the design diagram.
P****ene
Feb 25.2024, 15:54:58
Particular interviews furnish firsthand message on mart size, industry trends, ontogeny trends, capitalist landscape and outlook, etc. funny shirt ideas for country couples
P****ene
Feb 25.2024, 00:25:24
I am extremely delighted in for this web journal. Its a useful subject. It help me all that much to take care of a few issues. baby shower onesies gift Its chance are so awesome and working style so rapid.
P****ene
Feb 24.2024, 16:46:01
Very informative article regarding PCB design. news from Qatar One can learn a lot about the PCB designs from this article.
P****ene
Feb 17.2024, 17:31:15
I want you to thank for your time of this wonderful read!!! I definately enjoy every little bit of it and buy adderall online I have you bookmarked to check out new stuff of your blog a must read blog!
P****ene
Feb 06.2024, 17:15:53
Very interesting blog. A lot of blogs I see these days don't really provide anything that I'm interested in, but I'm most definitely interested in this one. Just thought that I would post and let you know funny lingerie
P****ene
Feb 03.2024, 15:56:38
Thanks for sharing nice information with us. I like your post and all you share with us is up to date and quite informative, I would like to bookmark the page so I can come here again to read you, as you have done a wonderful job. Golf Kemayoran
Dec 26.2023, 22:06:10
With a background in electronics engineering, I appreciate the insightful best place to buy diamond rings exploration of common problems in PCB design. This guide adeptly navigates through crucial issues, offering solutions to ensure optimal functionality and reliability. Addressing these ten pitfalls is indispensable for engineers striving to create robust and efficient printed circuit boards.
Nov 24.2023, 11:16:48
It is necessary to ensure that all components are placed so that they not only fit in terms of size but also ensure performance aa route planner and cooling.
