t****boy
10 Tips for PCB Stackup Design
609 7 Sep 30.2022, 16:38:05
With the continuous emergence of high-speed circuits, the complexity of PCB boards is also getting higher and higher. In order to avoid the interference of electrical factors, the signal plane and the power supply layer must be separated, so it involves the design of multilayer PCB, that is, the design of laminated structure.
1. Avoid Direct Connection of Two Signal Planes
In a multilayer PCB, it usually includes a signal plane (S), a power plane (P) plane and a ground plane (GND). How are the three arranged?
Power and ground planes are usually undivided solid planes that provide a good, low-impedance current return path for current from adjacent signal traces. Therefore, the signal plane is mostly adjacent to the power plane or the ground plane. Moreover, the power supply layer and ground plane use a large area of copper (so the power supply layer and ground plane are also called copper layer), and the large copper film can provide shielding for the signal plane, which is conducive to impedance control and improvement of signal quality.
In addition, should try to avoid two signal planes directly adjacent to each other. Crosstalk is easily introduced between adjacent signal planes, resulting in circuit failure. Adding a ground plane between the two signal planes can effectively avoid crosstalk.
2. Most Top and Bottom Planes are Signal Planes
The top and bottom planes of a multilayer PCB are usually used to place components and a small number of traces, so they are mostly signal planes. Generally, the top plane is the component, and the bottom plane (the second plane) of the component can be set as the ground plane, providing the device shielding layer and providing the reference plane for the top plane wiring.
In addition, note that these signal traces on the top and bottom planes cannot be too long to reduce direct radiation from the traces.
3.Reference Plane Preferred the Ground Plane
Both the power plane and the ground plane can be used as reference planes and have a certain shielding effect.
The difference between the two is that: the power supply layer has a high characteristic impedance, and there is a large potential difference with the reference level; while the ground plane is generally grounded and used as a reference point for the reference level, its shielding effect is much better than that of the power supply layer.
Therefore, when choosing a reference plane, the stratum is preferred.
4. The High-speed Signal Layer is Located in the Middle Plane of the Signal
The high-speed signal transmission layer in the circuit should be the signal intermediate plane and sandwiched between two copper layers. In this way, the copper film of the two copper layers can provide electromagnetic shielding for high-speed signal transmission, and at the same time, it can effectively limit the radiation of the high-speed signal between the two copper layers without causing external interference.
5.The Power Plane and the Ground Plane are Preferably Paired
The power supply layer and the ground plane appear in pairs, shortening the distance between the power supply and the ground plane can reduce the impedance of the power supply, which is beneficial to the stability of the power supply and reducing EMI. In particular, the main power supply should be as adjacent to its corresponding ground plane as possible. In the case of high speed, you can add extra ground planes to isolate the signal plane, but it is recommended not to add more power planes to isolate, because the power plane will bring more high-frequency noise interference.
6.Copper Layer Balance Design
The copper layer, that is, the power plane or the ground plane, is best arranged symmetrically, such as the second plane and the fifth layer of the 6-layer board, or the third layer and the fourth layer should be copper-plated together, which is considered to be flat and horizontal in the process. Structural requirements, as unbalanced copper layers may cause warpage as the PCB expands.
7.Multiple Power Planes away from High-speed Signal Planes
Multiple power supply layers should be kept away from high-speed digital signal wiring. Because the multi-power supply layer will be divided into several physical regions with different voltages, if the signal power is close to the multi-power supply layer, the signal current on the nearby signal layer will encounter an unsatisfactory return path, making the return path A gap appears.
8.Use Even-numbered layers
The classic PCB stack-up design is almost entirely even-numbered, not odd-numbered. Even-numbered layers of printed circuit boards have cost advantages, and even-numbered layers are more resistant to board warpage than odd-numbered layers.
9.Arrange Routing on Adjacent Layers
In order to complete complex wiring, the transition between layers of traces is inevitable. The two layers spanned by a signal path are called a "routing combination". The best routing combination design is to avoid return current flow from one reference plane to another reference plane, but rather to flow from one point (surface) of one reference plane to another point (surface).
Therefore, wiring combinations are preferably arranged on adjacent layers, because a path through multilayers is not clear for return currents. Although the ground bounce can be reduced by placing decoupling capacitors near the vias or reducing the thickness of the dielectric between the reference planes, it is not a good design.
10.The Routing Directions of Adjacent Signal Planes are Orthogonal
On the same signal plane, the direction of most wiring should be consistent, and it should be orthogonal to the wiring direction of adjacent signal planes. For example, the wiring direction of one signal plane may be set to the "Y-axis" direction, and the wiring direction of another adjacent signal plane may be set to the "X-axis" direction.
On the other hand, how to do impedance control is a headache for many users, but PCBGOGO makes everything so easy. PCBGOGO will automatically calculate the line width and line spacing corresponding to different impedance controls according to different stacks, so as to do impedance matching for the user, without the need to perform complex impedance calculations manually, saving effort and worry!
When PCBGOGO places an order and selects the stack structure, select "Custom Stackup" with one click, and professional engineers will follow up the order and help customers to do stack production.
PCBGOGO has offered high-quality PCBs and the best PCB assembly service all over the world since 2015.
It has been specializing in quick-turn PCB prototyping and turnkey PCB assembly services and are one of China's leading companies in the industry.
  • Comments(7)
Apr 20.2024, 00:59:10
I have been looking for a very long time for a site where I can watch the weather in the city of Zamo??. It is important for me to know what weather will be waiting for me tomorrow or today. And I am really glad that on this https://icmmeteo.pl/21468/zamosc-5 site I found a great service that shows accurate weather forecasts. I want to share this service with you so that you too can watch accurate weather forecast in Zamo?? city
L****ana
Mar 16.2024, 05:34:58
[URL=https://translate.google.com/]anchor[/URL] [link=https://translate.google.com/]anchor[/link] <a href="https://translate.google.com/">anchor</a> [url=https://translate.google.com/]anchor[/url] anchor
L****ana
Mar 16.2024, 05:34:50
Using [url=https://barz-casino-win.com]Barz Casino[/url], you will find not only a wide selection of slot machines, card games and roulette, but also many other exciting games that can satisfy the most refined tastes of gamblers in the UK. This site opens the doors to an exciting world of gambling entertainment, where every player can find something to his or her liking and enjoy the atmosphere of excitement and the possibility of winning.
L****ana
S****els
Feb 29.2024, 00:03:15
With Dripify's Extra Safety Algorithm, I can be confident that my LinkedIn account is safe. Ensure the safety and security https://dripify.io/features/extra-safety-algorithm/ of your LinkedIn account with Dripify's advanced safety features. Dripify not only automates repetitive tasks on LinkedIn but also prioritizes safeguarding your account in 2024, allowing you to save valuable time for your business needs. This algorithm carefully analyzes my activity and helps me avoid any violations of the platform's rules.
Feb 05.2024, 22:51:34
 My experience with the site where I purchased Dart CH16DEF https://mcdonaldpaper.com/dart-ch16def-16-oz-clear-tamper-evident-containers-with-flat-lid-200-cs/ 16 oz clear containers with flat lids has been outstanding. The ordering process was straightforward, and the containers arrived promptly. The 16 oz size is perfect for larger servings, and the clear design allows for easy visibility of the contents. The flat lids seal tightly, ensuring freshness and preventing spills. I highly recommend both the Dart containers and this user-friendly website for a seamless shopping experience.
Jan 03.2024, 22:30:10
This essay service, my dears, is a marvel. It rescued me from the dread of tight deadlines. Used it to do my essay – https://studyfy.com/. The writers are truly splendid, easing the weight of academic tasks. For those seeking reprieve from essay woes, consider this gracious assistance. A reliable companion for academic tranquility, indeed.
