M****ong
Choosing the Correct Thickness for PCB Prototype
25568 10 Dec 03.2018, 10:56:37
Introduction:
While manufacturing a PCB, there are many factors that will influence the performance of your PCB. One of them is the thickness of your PCB. The thickness will affect the conductivity and resistance of your PCB and so you will have to choose the perfect thickness so your PCB can fit its applications accurately. In this article we will discuss the various standards of thickness available for PCBs and how you can choose the correct standard for yours.
There are a number of things to consider before you make your choice. The application is a major factor but the profile, weight, components etc. all play a part too. Over years the size of PCBs has grown smaller, lighter and thinner so the thickness should also fit these standards.
PCB Thickness Options:
The number of layers your PCB determines the overall thickness of your PCB. Some applications require a thicker PCB while some require a thinner type. SO the thickness has very varying standards. The typical range of thickness for the core and prepreg combined is between 0.008 -0.240 inches.
Standard PCB Thickness:
PCBs can be single sides, double sided or multi layered. The typical thickness is 0.063 inches (1.57mm) which is a standardized level from the past. This is because of the 0.063 inches plywood sheets used as substrates in electronic devices during the plywood industry. Today,the thickness range however is 0.008-0.240 inches which you can choose from. This is because of the development of multi-layer PCBs. Also over time, the use of substrates better than plywood started for example, epoxy.
PCB Copper Thickness:
Copper plays a role in the overall thickness of the PCB. The copper thickness usually depends on the current passing through the PCB. The standards copper thickness is roughly 1.4 mm to 2.8 mm (for internal layers) and 2-3 oz.(including the external layers). The thickness is adjusted according to your requirements. Keep in mind that increased copper means higher price and challenging processing.
PCB Trace thickness:
PCB trace thickness is usually specified in by the designer. Usually when the current flow increases the copper traces can overheat and can damage the PCB. So the trace should be thick enough to accommodate the higher current without overheating the PCB. To determine the proper thickness the amount of current passing through the PCB is compared to the rise in temperature. The width that can accommodate the average to maximum operating temperature is the thickness.
How to Specify PCB Thickness:
You can specify the thickness of your PCB by using a trace width calculator. Simply input all the specifications and the calculator will give you the requirement average thickness. Factors such as the prepreg thickness, solder mask thickness etc. is required. You can calculate up to the hundredth of a millimeter to ensure accuracy in measurements.
Choosing the Thickness of PCB:
When choosing thickness remember that a thicker board is less likely to break as compared to a thin one. Unless the application calls for a thin board, it is better to stick to a thick one. The following factors should be kept in mind while choosing the thickness of PCBs.
1. Weight: A thinner board will break easily as it is more brittle. Therefore thicker boards are preferable unless the applications require a thin board.
2. Flexibility: Thin boards are more flexible as compared to thick ones but can break easily. Thick boards are less flexible and are heavier.
3. Space Required: If your device will have larger space for a larger PCB then using a thicker board is better but if you have a smaller device then it will require a smaller board.
4. Connections and components: The type of connectors and components you use will also require a certain thickness.
5. Impedance: It is integral to match the thickness of the board to the impedance. This is because the thickness of board is actually the thickness of the dielectric and the dielectric helps with impedance control.
PCBGOGO Quick Turn PCB Fabrication and PCB Assembly Manufacturer
  • Comments(10)
b****kay
Apr 25.2024, 09:32:39
Geometry dash lite is a rhythm-based platformer game that will test your reflexes and timing.
Feb 19.2024, 16:19:00
Whether you're a beginner or an experienced player, our guide will help you refine your strategies and overcome the game's obstacles with ease. Hello Neighbor
K****ey
Jan 31.2024, 12:59:46
The PCB's resistance and conductivity will be impacted by its thickness. There are a lot of standards to develop, but accuracy is needed. It also depends on the type of PCB—rigid or flexible—and its thickness.  spend elon musk money
Dec 21.2023, 06:56:12
Your passion for this subject is contagious. Thanks for inspiring! Parenthood announcement
s****son
Nov 27.2023, 15:43:30
The thickness of the PCB will affect the conductivity and resistance of the PCB. There are many standards to come up with but it requires precision. It also depends on how thick the PCB is, what type of PCB it is, flexible or rigid. Refer further to IPC standards tap tap shots
p****nge
Nov 27.2023, 11:36:24
Each type of circuit board requires its own standards. Refer to the IPC bad ice cream standard to make the best decisions.
Nov 24.2023, 11:13:10
With each different project and product, the exact thickness slither io for the PCB prototype will vary and it is essential to choose carefully.
Nov 24.2023, 11:12:40
With each different project and product, the exact thickness [url=https://slitherio.online]slither io[/url] for the PCB prototype will vary and it is essential to choose carefully.
Nov 24.2023, 11:12:19
With each different project and product, the exact thickness <a href="https://slitherio.online">slither io</a> for the PCB prototype will vary and it is essential to choose carefully.
K****ey
Oct 27.2023, 09:30:54
You've come this far and I think that's great, keep io games chasing your dreams and one day you'll reach the top and then you'll see how great you've become .
