E****son
How Does Electrical Testing Work in PCB Manufacturing
831 16 Apr 29.2022, 17:18:39
In the manufacturing process of PCBs, electrical defects such as short circuits, open circuits, and leakage might occur due to external factors. As PCBs continue to evolve towards high density, fine pitch, and multi-layers, the difficulties and cost of rework will significantly increase if the defective board is not screened out at an early stage and flow into the following-up process. To improve the rate of qualified products, electrical testing must be conducted in the PCB manufacturing process.
Some key terms:
Net: A net on a printed circuit board is a set of points that are electrically connected to a start and endpoint by the traces we design. It includes component pads, traces, test points (if any), and copper planes associated with the same connection.
Netlist: It refers to a connected group of two or more points in a PCB that share common electrical properties.
Main procedures of electrical testing
Capacitance Testing:
It is to detect the shorts on the board. By applying a charge to reflect the capacitance in the different Nets, it compares its value with the value of the board under test and generates a Netlist where the measurement does not correspond.
Continuity Test
This test is designed to detect shorts between different Nets making up the circuit to ensure that no current flows between them.
Insulation testing
Some small cooper residues may remain on the board surface after the chemical manufacturing process of the PCBs. They would not necessarily lead to shorts but may shorten the width of the traces. This testing is to find out these defects between the Nets to avoid unexpected electrical interactions such as voltage jumps or current leakage.
Types of electrical testing
Bed of nails testing
The bed of nails tester is a relatively traditional testing method that requires specific fixtures that contain standoff pins and plexiglass layers with holes drilled to support the springs pins. Fixtures with springs are attached to each test point on each board. The spring can provide each test point with 100g-200g pressure to ensure good contact with the test point. Arranged in a matrix that looks like a bed of nails, these fixtures are controlled by testing software and programming. With these testers, we are able to verify the condition of all the test points.
This test method requires specific fixtures, and the storage of the fixtures also takes up space, which is not economical. But its test speed is fast, and the fixture can be used repeatedly, making it an ideal testing method for batch PCB production.
Flying probe testing
The flying probe test uses 4 to 8 probes to conduct high-voltage insulation and low-resistance continuity tests on the circuit board. During this process, the board is placed vertically in the frame. The test probes are moved in the XY direction on both sides of the circuit to be set exactly on the pads whose electrical characteristics need to be tested. The test leads are then moved on the Z-axis until they make contact with the pads. The whole testing process is computer-controlled and the software will perform the required measurements and display the results to determine if the board is correct (PASS) or rejected (FAIL).
Flying probe testing machine in PCBGOGO
Flying probe testing is the most widely used method today, offering greater reliability. Its testing speed is slower than the bed of nails tester, taking several minutes to complete the test on a single board. However, it doesn't need specialized fixtures that require several days to develop the testing device, which significantly reduces product design cycles and time-to-market. This quality makes it an effective option for PCB prototypes and small-batch production. As a professional PCB manufacturer,  PCBgogo conducts flying probe testing on every board before being delivered to the customers.
 Flying probe testing lines in PCBGOGO
Electrical testing is a necessary part of PCB manufacturing. It can find out the defects at an earlier stage, help save money and prevent issues before reaching the final production phase. However, electrical testing can only detect certain defects on PCBs.An appropriate combination of other testing techniques should be conducted during different production stages to ensure that customers get error-free boards.
  • Comments(16)
May 07.2024, 17:26:04
I feel more informed zapatas after reading this, thank you.
Apr 22.2024, 16:13:22
The PCB production process has officially been introduced into electronics factories to produce what products? I'm working on monopoly go and want to learn a little about the electronics field.
A****ren
Feb 29.2024, 16:24:16
Watermelon Game is the rebel in the gaming world, breaking free from outdated plugins like a fruity superhero.
K****ey
Jan 23.2024, 11:38:49
This test's objectives are to ensure that there is no current flowing between the several nets that make up the circuit and to locate any shorts between them. buildnow gg
T****mas
Jan 10.2024, 13:07:59
It’s not just about kid’s food at <a href="https://yummy-valley.com/">Yummy Valley</a>. It’s about parenting as a holistic experience. Our goal is to build a community of parents who support each other and help each other grow as parents.
A****ria
Dec 30.2023, 19:06:08
USA TODAY presents daily crossword puzzles on its website. Take on a new crossword every day and start with your very first free puzzle! <a href="https://wordpuzzles.io/">word puzzles</a>
Dec 29.2023, 14:52:58
Whether you're a casual gamer looking for a quick adrenaline rush or a dedicated player aiming to climb the global leaderboards, subway surfers caters to a diverse audience, making it a must-try for anyone with a smartphone or tablet.
d****nor
Dec 19.2023, 13:53:21
I am electrical student and I read your post and got good information for my study. And now I will tell you about the fashion in this winter season. This Office Christmas Party Jason Bateman Black Coat  is very good.
Dec 05.2023, 09:27:03
Electronic components are then placed onto the PCB according to the design. These components include resistors, capacitors, integrated circuits, Watermelon Game and other elements. Soldering is used to secure the components onto the board, creating the electrical connections.
C****nna
Nov 28.2023, 18:57:11
In PCB manufacturing, electrical testing is the linchpin for quality assurance. Employing techniques like Automated Optical Inspection (AOI) and In-Circuit Testing (ICT) ensures pinpoint accuracy in  verizon high speed internet in your area  detecting faults and validating circuit functionality. Rigorous testing protocols are the bedrock, guaranteeing that every component meets stringent electrical standards for a flawless end product.
C****nna
Nov 28.2023, 18:53:03
In PCB manufacturing, electrical testing is the linchpin for quality assurance. Employing <a href="https://highestspeedinternetinmyarea.com/verizon-high-speed-internet-in-my-area/">verizon high speed internet in your area</a> techniques like Automated Optical Inspection (AOI) and In-Circuit Testing (ICT) ensures pinpoint accuracy in detecting faults and validating circuit functionality. Rigorous testing protocols are the bedrock, guaranteeing that every component meets stringent electrical standards for a flawless end product.
C****nna
Nov 28.2023, 18:52:15
In PCB manufacturing, electrical testing is the linchpin for quality assurance. Employing  techniques like Automated Optical Inspection (AOI) and In-Circuit Testing (ICT) ensures pinpoint accuracy in .[verizon high speed internet in your area](https://highestspeedinternetinmyarea.com/verizon-high-speed-internet-in-my-area/detecting faults and validating circuit functionality. Rigorous testing protocols are the bedrock, guaranteeing that every component meets stringent electrical standards for a flawless end product
Y****lsa
Nov 23.2023, 15:15:19
The purpose of this test is to find any shorts between the several nets that make up the circuit and make sure that there is no current flowing between them.
ragdoll archers
K****ey
Oct 27.2023, 09:28:39
Electrical testing is essential in PCB production to identify flaws like open circuits and short circuits early on and avoid <a href="https://retrobowlcollege.io">Retro Bowl College</a> expensive rework. Accurate testing  enables increased rates of certified goods as PCBs are more sophisticated.
M****ard
Oct 20.2023, 17:59:24
This post solve my problem I got last week. Big thanks to the author. That's reason why I put  fnaf games here for you to relax.
Oct 15.2023, 10:34:19
In PCB manufacturing, electrical testing is vital to detect defects like short circuits and open circuits early, preventing costly rework. As PCBs become more complex, accurate testing ensures higher rates of qualified products. Sophisticated methods like automated optical inspection and flying probe testing are employed to identify issues. Similarly, in arboriculture, assess the general health of trees and diagnose problems are crucial. Experts use various techniques to ensure the trees' well-being. For more information on electrical testing or tree health, click play now.
