E****son
How does Functional Testing work in PCB Assembly?
781 6 Jun 06.2022, 10:04:49
In every industrial setup, some things define acceptable and nonacceptable behaviors.  This could be defined in the requirement or functional specifications. It is a guide that explains what the user is allowed to do and how he can determine the system and application conformance to it. In addition, this could include the exact business scenario that should be validated. In these introductory remarks, it is good to take note that functional testing can be carried out by making use of these two well-known techniques:
Requirement-based testing: this will entail all functional specifications that will form the foundation of all the other tests to be carried out.
Business scenario-based testing: here it is done based on the information that is perceived from how the system will behave when it is ready for business or market point of view.
The PCB design process involves several components that are required to achieve several functions. These components must be tested to ensure that they achieve the required goals. In this article, we are going to emphasize functional testing. The most important thing that can be done during the functional testing process is the validation of the software that has been programmed into the IC during the IC programming process. This ensures that the programmed IC functions as it is intended. Let us jump into the definition of functional testing.
Functional testing inside PCBGOGO
Definition of functional testing
This is the process of testing the functionality of the circuit components and the loaded programs to ensure that they are functioning as expected.
  • In simple words, it plays a role in verifying the functionality of the loaded software after burning the ICs.
  • This process is also labeled as specification-based testing as the process depends on the specifications of the program.
Let us look at what you need to test during functional testing:
Mainline functions: this involves doing tests on the application’s main functions.
Basic usability: this will check if the user can use the software with ease and navigate through the screens with perfection.
Error conditions: this checks on errors present and whether they are displayed.
Accessibility: This will check whether the user can access the system.
Types of functional testing
Unit Testing: This one is used by developers who have programmed different codes where the codes could be either related or unrelated to perform certain functionality.
The following has to be achieved in unit testing: line, code path, and methods coverages.
Smoke testing: This is testing that is done after every unit release and it aims to ensure that there is build stability. The other name for this process is built verification testing.
Sanity testing: This is very important testing that is carried out to make sure that all the functionalities of the application system work as per the expectation. It should be done immediately after the smoke test is complete.
Usability testing: This is done in a very special way where the product design is exposed to the end-user-like environment and tests it. The comfortability of the user is derived from the process and the feedback given is used to improve the product further. The process is similar to user acceptance testing.
Regression tests: this is the function that is carried out to make sure that the addition of the new code, fixing bugs, and other enhancements do not alter the functionality of the existing codes by creating breaks or even causing instability, and hence the program keeps working according to the designer’s specifications.
Integration tests: this test is done on different modules that are perfectly working but need to be integrated and work as a single unit.
Test equipment used in functional testing
  • Selenium: it is an open-source tool that is popular for functional testing. It is mostly used in the testing of web applications. The goodness of this testing tool is that it supports various operating systems.
  • TestComplete: This is available commercially for carrying out tests in desktop, mobile, and website apps. With it, be assured that most scripting languages will be tested such as c++, c, etc.
  • Sauce Lab: this makes the biggest web, desktop, and mobile phone apps.
  • The test control unit example is the FCT tester that caters to Dut’s external forces exposure and calibrates its reaction perfectly and gives real-time feedback.
  • Test adapter which offers a surface of connection between the DUT and the control unit.
  • Inspection software should be a real-time type which is necessary for programming. It is also good for executing sequence tests.
  • Sensors such as color sensors are used to generate environmental conditions.
Steps that should be followed while doing Functional testing
  • First, make sure that you can understand the requirements of the business.
  • Make a test plan in advance that you will follow.
  • Create functional testing cases through the inclusion of test data, inputs, and outputs.
  • Make sure the input data is created according to requirements.
  • While involving the test input data, make sure you execute the test data cases.
  • Do a comparison of the specific data output with the output that is expected by the use of the validation process.
  • Make identification of log defects that constitute the expected output and the actual output difference.
Functional testing advantages
It gives a better security outcome: when carrying out functional testing, its attributes look at the aspects of the software security. At the end of it, it will give out a decision that dictates whether the software is secured or not for the keep of the sensitive data from the user.
It gives the end-users great satisfaction: The test makes sure that the end-user gets a satisfying performance. The user will be guided on how to get the easiest way of using the complete software.
It removes defects from the software: once the software is taken through the functional testing process, all the bugs and the errors are pointed out and removed leading to a perfectly working software. This leads to defect-free software.
Summary
In the area of software, functional testing is the way of testing a project’s functionality and making sure that the system is working as it is intended to. This process confirms that the system is well functioning.
PCBgogo will always make sure that it does well in the area of PCB hardware assembly to meet the goals of your hardware before you proceed to programming and functional testing of your project.
  • Comments(6)
R****Kja
May 09.2024, 08:44:40
Looking for a reliable transaction platform was not easy, but I finally found one that stands out. The user-friendly interface coupled with seamless integration makes it a breeze to use. But, what truly impressed me was the high level of security it offers. You can find it at https://transferty.com/white-label-pg/ . It has quickly become my go-to solution for all my transaction needs. I highly recommend it to anyone looking for a reliable and efficient transaction platform.
K****ter
Apr 22.2024, 23:08:48
The online casino finland https://onlinecasinoprofy.co.uk/online-casino-finland/ page was a fantastic resource for finding Finnish-friendly online casinos. It covers all the essentials, such as licensing information, game selection, local payment options, and the overall quality of customer support. The thorough reviews have made it easier for me to choose a platform that not only meets my gaming needs but also provides a secure and welcoming environment for Finnish players.
Feb 22.2024, 15:19:20
Regression testing and usability testing are actually what I like most. I appreciate you providing many kinds of exams and poly track
Dec 21.2023, 06:37:44
I appreciate the clarity and simplicity of your writing. Confetti cannon
C****nna
Dec 04.2023, 15:25:41
Functional testing in PCB assembly is paramount for quality assurance. As an electronics cheapest bundle of tv internet and phone  expert, I emphasize its role in validating the assembled board's functionality. Rigorous testing, from power integrity to signal processing, ensures optimal performance. This meticulous process safeguards against defects, upholding the reliability and functionality of electronic systems.
K****tiz
Dec 01.2023, 14:44:58
Actually, I prefer regression tests and usability testing. Thanks for sharing all types of tests and uno online
