M****ong
How to open Gerber files in AutoCAD with free open source tools
8279 5 Oct 16.2018, 13:54:21
Here is a method for how you can import a Gerber RS-274X file into AutoCAD. There are many commercial software solutions to perform this, but this is how you can do it for free using open source tools!
You'll need to install and configure (if needed) the following software.
  • gerbv – this is used to view Gerber files, and can also export to a variety of formats (but not DXF or DWG for AutoCAD)
  • pstoedit – converts Postscript files to many different other formats
  • ghostscript – needed by pstoedit
Open your Gerber files in gerbv. This process work for multiple layers as well. You should see your Gerber to make sure it is what it should be.
Export the Gerber set to PostScript. File -> Export -> Postscript…
Optionally, if you don’t need to visually check the Gerber file in gerbv, gerbv supports exporting via the command line, for example:
gerbv -x ps MYGERBER.GTL
Now convert the Postscript (.ps) file to DXF using pstoedit. This is best done on the command line.
pstoedit -f dxf foobar.ps foobar.dxf
Now you should have a .dxf file which you can open in AutoCAD.
Caveats
When working with multiple Gerber files and you export them all at once to one .ps file, and convert them to a single .dxf, all the information comes up in AutoCAD as a single layer, but the original layers can be differentiated by their colours.
However you could manually move different colours to new layers if need be (using QSELECT command in AutoCAD). This probably could be scripted, but that’s a bit beyond my means at the moment.
  • Comments(5)
J****ruz
Apr 29.2024, 16:37:05
Lone Star Home Remodeling Pros Home Contractor
M****ton
Apr 11.2024, 14:36:40
This method offers a cost-effective solution for users who need to work with Gerber files in AutoCAD Tunnel Rush and prefer open source tools. Thanks for sharing!
B****ake
Dec 18.2023, 12:59:58
This is used to view Gerber files, and can also export to a variety of formats (but not DXF dinosaur game or DWG for AutoCAD)
B****man
Dec 01.2023, 15:19:22
Players can jump, shoot, and use power-ups to eliminate their opponents. Getaway shootout also features a variety of weapons, such as pistols, shotguns, and rocket launchers.
w****own
Nov 06.2023, 10:15:46
This board appears to be quite useful to me while I work on the geometry dash lite product. Thank you for informing the community.
