z****gyu
The Use of Silk Screen Technology in Printed Circuit Board (PCB)
6041 5 Oct 09.2018, 18:02:44
What is silk-screening?
Silkscreen is a layer of ink traces used to identify components, test points, parts of the PCB, warning symbols, logos and marks etc. This silkscreen is usually applied on the component side; however using silkscreen on the solder side is also not uncommon. But this may increase the cost. Essentially a detailed PCB silkscreen can help both the manufacturer and the engineer to locate and identify all the components.
The ink is a non-conductive epoxy ink. The ink used for these markings is highly formulated. The standard colors we normally see are black, white and yellow. PCB software also uses standard fonts in silkscreen layers but you can choose other fonts from the system too. For traditional silk-screening you require a polyester screen stretched on aluminum frames, a laser photo plotter, spray developer and curing ovens.
Method of Silk=screening:
There are three basic ways to apply silkscreen.
1: Manual Screen-printing:
Manual screen-printing is done when the line widths are greater than 7 mil (0.007”) and the registration tolerance is 5 mil. For this method you require a stencil of the text and traces made of nylon. The ink is pushed through the stencil onto the laminate. Next the board is baked in a curing oven for the ink to cure. The application and set up is easy but the result is least precise.
2: Liquid Photo Imaging (LPI):
This method is used when the line widths are greater than 4 mil. Liquid Photo Imaging is quite similar to the process used for the application of solder mask. In this a liquid photoimageable epoxy is coated on to the laminate and then exposed with UV light. After this the board is developed and cured. It is much more accurate than manual screening.
3: Direct Legend Printing (DLP):
DLP is the most accurate of all these processes but is more expensive. In this process an inkjet projector is used with acrylic ink that is applied onto the raw PCB directly from the CAD data. The ink is cured with UV light as it is printed. It should be noted though that the acrylic ink does not cure on boards with silver finishes.
Importance of Silk-Screen:
A properly designed silk-screen can prove to be highly useful as it can reduce the chance of error and can reduce time taken to spot the error. The silkscreen can easily label the passive components of the PCB no matter how packed the board may be.
There are a few things you should keep in mind regarding silk-screening. For example, the silkscreen epoxy should not be printed over pads or land PCBs that will be soldered as it will melt into the solder joint. This is why it should be applied over the solder mask. While designing you should keep the component outlines away from the pins (almost at a distance of 0.25 mm). Also you should check to see if the width of the silkscreen graphics is suitable to the design. Try to keep the line widths no less than 6 mil.
Knowing more about PCB and silk-screening can help you to reduce your PCB costs. For example, applying silk screen on only one side and choosing the standard colors will give you better overall pricing and give you the same benefits.
This ARTICLE is Proudly Presented by PCBGOGO
Best PCB Manufacturer in China – PCBGOGO Review
PCBgogo: Placing Your Order Made Easy | Best PCB manufacturers
  • header
  • Comments(5)
J****son
May 06.2024, 17:59:38
Out of all the games I've played, I find the love tester to be the most enjoyable. It's engaging and never fails to entertain. The premise is straightforward: input your name and your crush's name, and the game will determine your compatibility. What's more, if you have more than one crush, simply reload the page, enter your name and the next crush's name, and the game will analyze the results once more. It's so much fun!
J****son
May 06.2024, 17:54:16
Among all the games out there, my absolute favorite is the <a href="https://love-tester.io/">love tester online</a>. This game is just so much fun and addictive. It's super simple: just type in your name and the name of your crush, and the game will assess your compatibility. And if you're juggling multiple crushes, no problem! Just refresh the page, input your name along with the next crush's name, and the game will give you the results again. It's a riot!
B****dam
Mar 17.2024, 07:53:15
In the last stretch of my university journey, I found myself inundated with a multitude of assignments. Each one seemed to demand my full attention and time, leaving me mentally drained and physically exhausted. https://royalwriter.co.uk/do-my-dissertation To be quite honest, the mere thought of tackling my dissertation seemed like an insurmountable task. It was the proverbial straw threatening to break my back. Out of desperation, I decided to entrust this significant piece of my academic career to an online service.
B****dam
Mar 17.2024, 07:51:57
In the last stretch of my university journey, I found myself inundated with a multitude of assignments. Each one seemed to demand my full attention and time, leaving me mentally drained and physically exhausted. royalwriter.co.uk To be quite honest, the mere thought of tackling my dissertation seemed like an insurmountable task. It was the proverbial straw threatening to break my back. Out of desperation, I decided to entrust this significant piece of my academic career to an online service.
Mar 06.2024, 05:09:16
https://www.linkedin.com/pulse/6-best-pay-someone-write-my-essay-services-tracy-angus-5wojc, traditionally a professional networking platform, is evolving into a dynamic space for academic discussions. Engaging on LinkedIn provides students with diverse perspectives on essay writing services. The platform's professional ethos ensures insightful conversations, making it a valuable forum for those seeking guidance on how to write an essay effectively.
