5G Module HDI PCB High Frequency Material Selection Guide
159 0 Sep 21.2026, 18:08:00
QUICK ANSWER  Choose a 5G module HDI PCB laminate by the loss budget of its actual RF path, not by the 5G label alone. Compare Dk and Df at a stated test frequency, then check copper profile, thermal behavior and compatibility with laser microvias and sequential lamination. A qualified hybrid stackup can reserve premium material for the layers that need it.
A compact module may put an antenna feed, transceiver, power circuitry and dense BGA escape routing on one board. The dielectric that works for a short control trace may be a poor choice for a long millimeter-wave feed. The practical task is to connect electrical performance to a buildable HDI stackup and a realistic bill of materials.
Which material properties matter most for a 5G HDI PCB
Material selection begins with the specific signal path, operating band and allowable insertion loss. Dk affects propagation and impedance; Df contributes to dielectric loss. Neither value is a universal pass or fail threshold for every Sub-6 GHz or millimeter-wave design. Ask for values measured at a relevant frequency and by a known method, then use the production laminate and finished geometry in your field solver.
For example, PCBgogo lists Rogers RO4003C at reference Dk 3.55 and Df 0.0027, and RO4350B at Dk 3.48 and Df 0.0037, both at 10 GHz. Those are initial screening values, not interchangeable inputs for every copper thickness, prepreg or frequency. A successful RF path also depends on trace width, dielectric thickness, return-plane continuity, plating and transitions.
  • Copper profile: Rough copper raises conductor loss as current concentrates near the surface at high frequency. Request an appropriate low-profile foil and confirm that its bond and etching process suit fine HDI features; the lowest roughness is not automatically the best manufacturing choice.
  • Thermal and moisture behavior: Compare glass transition temperature, Z-axis expansion, moisture uptake and Dk stability over the module's operating conditions. Repeated lamination and reflow stress vias and interfaces, so a low Df alone cannot establish reliability.
  • Build-up compatibility: Confirm laser drillability, resin flow, bondply, minimum dielectric thickness and via-fill approach with the fabricator. A laminate intended for RF cores may need a different build-up dielectric for a stacked microvia structure.
The right target is measured performance after fabrication, not the smallest number on a catalog sheet. This is especially important when material substitutions or a change in copper foil affect a released impedance model.
How to compare practical laminate choices
The table separates RF transmission layers from structural and power layers. It is a shortlist for engineering review, not a claim that every named grade suits every HDI stackup.
Material routeWhere it can fitCheck before release
High-Tg epoxy, such as Shengyi S1000-2M or ITEQ IT-180AHDI cores, power and shorter lower-loss-budget pathsDo not assume RF performance from Tg; model and test the route
Ceramic-filled RF, such as Shengyi SJ9033/SJ9036 or Rogers RO4003C/RO4350BControlled-impedance Sub-6 GHz and selected higher-frequency RF layersMatch grade, bondply, copper and lamination process
Very-low-loss PTFE, such as Rogers RO5880 or qualified Taconic familiesDemanding millimeter-wave feeds or antennasConfirm drill, bonding, registration and via strategy
Hybrid RF laminate plus qualified FR-4RF layers that need lower loss, with cost control elsewhereValidate CTE, resin compatibility and sequential lamination
A supplier name alone is too coarse for a fabrication specification. ITEQ IT-180A, for example, is listed by PCBgogo as a high-Tg epoxy option, not as a direct substitute for an ultra-low-loss RF laminate. Specify a grade, thickness, foil and permitted substitutions rather than writing only a brand on the drawing.
Match the HDI structure to the RF stackup
HDI density and RF loss solve different problems, so the layer plan must satisfy both. A one-stage 1+N+1 build may escape a compact BGA with fewer sequential cycles. A two-stage 2+N+2 or more complex design creates tighter registration and thermal demands; stacked versus staggered microvias, via-in-pad and bondply choice need fabricator review before the layout is locked.
Place critical RF routes over a continuous reference plane, keep transitions short, and model the real via and launch geometry. A hybrid board can use Rogers or Shengyi RF material where antenna or RF feeds need it and qualified FR-4 on less sensitive layers. That does not mean simply pressing two materials together: resin systems, expansion, bond strength, drill behavior and lamination cycles must be compatible. PCBgogo lists both pure RF and hybrid constructions among its advanced PCB options, subject to stackup review.
Budget the path rather than the entire board. If a short Sub-6 GHz trace on a characterized high-Tg epoxy meets the insertion-loss and impedance targets, an all-PTFE stack may add cost without improving the module. Conversely, a long or tight-margin millimeter-wave feed may justify a dedicated low-loss layer and controlled copper profile. Validate this choice with coupons or assembled RF measurements at the frequencies that matter.
Avoid these material selection errors before production
A repeatable selection process prevents an attractive datasheet value from becoming an expensive production surprise.
  • Treating Dk below 3 as a millimeter-wave rule: Some viable RF laminates have higher Dk. Loss, dimensional stability, geometry and the antenna design decide whether the material works.
  • Comparing Df values without test conditions: Frequency, temperature and measurement method can change the comparison. Capture the supplier's exact datasheet conditions in the design record.
  • Prototyping on a different material: A late laminate or foil swap changes impedance and loss. Freeze the approved stackup, copper type and substitution policy before a pilot run.
  • Ignoring the inspection plan: Agree on impedance coupons, electrical test and any cross-section or thermal reliability checks appropriate to the via structure. Assembly testing should be defined separately from bare-board acceptance.
Share expected volume and sourcing constraints early. The cheapest laminate quote is not the cheapest route if it forces a redesign or an unqualified high-order HDI process.
How PCBgogo supports material choice through finished boards
Once the RF path and HDI architecture are defined, a single manufacturing review can connect the laminate shortlist with the production process. PCBgogo's published advanced PCB options include Rogers RO4003C, RO4350B and RO5880, qualified Shengyi RF grades, ITEQ high-Tg epoxy, PTFE families and hybrid RF/FR-4 builds. Exact grade, thickness, copper and availability should be confirmed for each order.
Its published capabilities include sequential lamination, stacked or staggered laser microvias, via-in-pad, fine-line routing and controlled impedance. The advanced PCB page lists HDI boards at 4 to 14 layers and a 0.10 mm minimum finished laser aperture; the construction still needs a manufacturability review. PCBgogo also offers electrical testing and inspection, with component sourcing, SMT or through-hole assembly, AOI, X-ray and customer-defined functional testing available for a completed PCBA. Keeping material selection, fabrication, inspection and assembly in one coordinated workflow can reduce handoffs and save engineering time.
For a quote, register with PCBgogo and upload the Gerber file or ODB++ data, drill files, board outline, proposed stackup and impedance targets. Include the RF frequency, approved laminate codes, no-substitution notes, expected quantity and any assembly BOM. Ask the team to confirm the feasible construction and test plan before committing to a production material.
     Get Free Quote  >
Frequently asked questions
Can standard FR 4 work in a 5G module
Yes, on some short or less loss-sensitive paths if simulation and test show adequate margin. A 5G radio label alone does not make every layer a premium RF layer; long or demanding RF paths need closer loss analysis.
Is a lower Dk always better for 5G RF traces
No. Dk affects trace geometry and propagation, while Df, copper loss and transitions affect insertion loss. Choose a laminate against the complete channel and antenna design.
Should every layer use the same high frequency material
Not necessarily. A reviewed hybrid stackup can place RF material only where it earns its cost, while other layers use a compatible, less expensive dielectric. Thermal and lamination compatibility must be verified.
What should be sent with an HDI PCB quotation
Send fabrication data, the stackup, via structure, impedance and RF requirements, approved material grades, volume and test expectations. Add the BOM and placement data if assembled boards are required.
Final material selection checklist
Define the RF path and loss budget, compare grade-specific data under matching test conditions, then qualify the copper, build-up dielectric and HDI process as one system. PCBgogo can review the material options and carry the approved design through fabrication, inspection and finished PCBA. Register and request a project-specific quote with your stackup so the selection is tested against a buildable process.
