Shinna Hu
How PCI-E Card Helps In Port Expansion And Cable Management?
1998 15 Jun 21.2019, 17:54:00
A PCI-E or “Peripheral Component Interconnect Express” card is a computer extension card interface used for making the motherboard level connections. The standard card not only provides for better management of the cables but also enhances the speed of data exchange.
Why You Need PCI-E Card For Port Expansion?
PCI-E card is a multi-featured and potent component and accessory for port expansion.  Through the extra ports, you can add all the devices to your computer that you want or require. The card provides for easy and swift upgrades as well, and is suitable when you want to give new dimensions/features to your system. It gives a clear path to the processes and also helps in other tasks like reseating of RAM, or cleaning of the air filters.
Bunched cables may also reduce the air flow and may result in higher system temperature. Temperature increase can be alarming while playing games or running the other high-end applications. Cables may also get intertwined with other components like fans and cause a dangerous situation. Apart from solving these issues, the PCI-E card also provides for better aesthetics and looks of the system.
PCI-E Card for Cable Management
You can easily buy a 4, 5 or 7 USB port PCI-E card and connect all kinds of USB devices. You can transfer data, video, music and much more at 5 Gbps speeds, and the card also offers you the lowest energy consumption benefits.
The PCI-E card also comes along with the cables that prove to be effective cable management solutions. They can be used at the servers and computers and can connect the power supplies and the GPUs. Because the cards contain the solid capacitors and the filtering units, reliable and secure connectivity is guaranteed.
PCI-E USB card also has low latency. All the devices have their own dedicated point of connection on the card, and therefore do not compete with each other for procuring the bandwidth. The cards may have a minimum of 1 to a maximum of 32 lanes. The card can enable a data manager to have multiple high-speed networking connections (including RAID, Gigabit Ethernet, and others).
The benefits of a PCI-E card go much beyond port expansion. They help in cable management, are highly effective, and are also a neat and clean way to add devices to any computer. Also, the cards take the least amount of space.
About the author:
Inateck is a leading electronics company dedicated in the field of various high-quality niche electronic related products. With 6-year experience, they are particularly professional for cutting-edge barcode scanners, hard drive accessories like PCI-E card, HDD enclosures & docking station, laptop sleeves and more.
