Cayla CC
How to Repair BGA Solder Ball Bridging Faults
2380 0 Apr 17.2025, 17:17:00
1. Common Causes of BGA Solder Ball Bridging and Simple Repair Methods
Repair Methods:
  • Hot Air Gun Repair: Use a hot air gun at 245°C to locally heat the bridging area, then gently separate the solder balls with fine-tipped tweezers.
  • Solder Wick Treatment: If the bridging is mild, use solder wick in combination with a soldering iron (around 300°C) to remove excess solder.
  • Flux Adjustment: Choose low-residue, high-activity flux, such as the JDB-200 series recommended by PCBGOGO, which can effectively reduce the risk of bridging.
Preventive Measures:
  • Stencil Thickness Control: Keep the stencil thickness within 0.1mm, with an opening ratio of 1:0.9 recommended.
  • Reflow Soldering: Maintain a heating rate of ≤2°C/s during reflow soldering to avoid solder paste splashing.
2. How to Avoid Bridging Issues in BGA Soldering? 3 Key Points
Stencil Design Optimization:
  • Stencil Opening: The stencil opening should be slightly smaller than the pad (a 90% ratio is recommended).
  • Precision Stencil: PCBGOGO's laser-cut stencils have a precision of ±5μm, effectively reducing excess solder paste issues.
Solder Paste Printing Control:
  • Type 4 Solder Paste: Use Type 4 solder paste with finer particles, suitable for high-density BGAs.
  • Placement Timing: Complete component placement within 2 hours after printing to avoid solder paste oxidation.
Reflow Soldering Temperature Profile:
  • Preheating Stage (120-180°C): Keep the preheating time between 60-90 seconds to allow the flux to fully evaporate.
  • Peak Temperature: Recommend a peak temperature of 245°C to avoid excessive melting of solder balls.
3. Quick Diagnosis and Repair Techniques for BGA Bridging Faults
Diagnostic Steps:
  • X-Ray Inspection: Confirm the bridging location to avoid blind operations.
  • Microscope Observation: Check for solder ball deformation or adhesion.
Repair Techniques:
  • Localized Heating: Use a hot air gun (240-250°C) to target the bridging area, and adjust with tweezers once the solder softens.
  • Solder Paste Rework: For severe bridging, reballing is necessary. Recommend PCBGOGO's BGA rework station for precise temperature control and higher success rates.
Preventive Suggestions:
  • Regular Stencil Inspection: Check for deformation or blockages in the stencil.
  • High-Precision Placement Machine: Use high-precision placement machines to reduce the risk of misalignment.
4. Solutions for Bridging Issues in Lead-Free BGA Soldering
Solutions:
  • Reflow Profile Adjustment: For lead-free solder, the peak temperature should be around 250°C, with a gentle heating rate of 1.5-2°C/s.
  • Flux Optimization: Choose high-activity flux, such as PCBGOGO's JDB-300, to improve solder flow and reduce bridging.
Common Mistakes:
  • Excessive Temperature: Leading to over-melting of solder balls.
  • Large Stencil Opening: Resulting in uncontrolled solder paste volume.
5. Practical BGA Rework: How to Perfectly Repair Solder Ball Bridging?
Operational Steps:
  • Pad Cleaning: Use anhydrous ethanol to remove residual flux.
  • Localized Heating: Use a hot air gun at 245°C, set the airflow to level 2, and evenly heat the bridging area.
  • Separate Solder Balls: Gently push the solder balls back into place with a fine-tipped tweezers.
Recommended Tools:
Precautions:
  • Stabilize the PCB: Keep the PCB stable during operation to avoid secondary damage.
  • Post-Repair Inspection: Conduct X-Ray inspection after repair to ensure no remaining bridging or cold soldering.
