Cayla CC
Implementation Case of PCBA Process Change Management
1600 0 Apr 21.2025, 14:18:00
In the electronics manufacturing industry, process change management for PCBA (Printed Circuit Board Assembly) is a key link in ensuring product quality, improving production efficiency, and reducing costs. This article shares the implementation experience of PCBA process change management through a practical case, hoping to provide some references for industry insiders.
Case Background
A consumer electronics manufacturer primarily produces consumer electronic products. Its PCBA production process is relatively complex, involving multiple procedures and suppliers. In recent years, with intensified market competition, the manufacturer has faced multiple pressures of cost control, shortened delivery times, and improved product quality.
Implementation Steps of Process Change Management
Current Status Analysis: First, the manufacturer conducted a comprehensive assessment of the existing PCBA process, including the efficiency, yield, cost, and existing bottlenecks of each procedure. Through data analysis, it was found that the defect rate of the soldering process was high and the efficiency was low, which was the main factor restricting production efficiency.
Plan Formulation: The manufacturer developed a detailed process change plan, including the introduction of automated soldering equipment, optimization of soldering parameters, and improvement of the process flow.
Risk Assessment: Before implementation, the manufacturer assessed potential risks, including equipment failure, personnel training, material compatibility, etc.
Pilot Operation: A production line was selected for pilot operation, with real-time monitoring and data analysis of various indicators, and the plan was adjusted and optimized according to the actual situation.
Full-scale Rollout: After the successful pilot operation, the new process flow was rolled out to all production lines, and relevant personnel were trained.
Continuous Improvement: A continuous improvement mechanism was established to regularly evaluate and optimize the process flow, in order to continuously improve production efficiency and product quality.
Implementation Effects
By implementing PCBA process change management, the manufacturer achieved significant results:
  • The defect rate of the soldering process was reduced by 60%, exceeding the expected target.
  • Production efficiency was increased by 35%, effectively shortening the delivery time.
  • Product quality was significantly improved, and customer satisfaction also increased.
  • Production costs were effectively controlled, enhancing the company's competitiveness.
It is hoped that this case can provide some references  and for peers in the electronics manufacturing industry. In actual operations, each company's situation is different, and it is necessary to formulate appropriate process change management plans according to one's own actual situation. At the same time, choosing a partner like PCBGOGO, which provides professional equipment and systems, can also provide strong support for the smooth implementation of process changes.
