Cayla CC
Inside the AOI and X-Ray Process for High-Quality PCBs
2332 0 Apr 11.2025, 15:57:00
As PCB complexity continues to rise, so does the need for more advanced inspection techniques to ensure flawless production. In high-end manufacturing environments, two essential technologies—Automated Optical Inspection (AOI) and X-Ray inspection—play a critical role in ensuring quality and reliability. At PCBgogo, we integrate both methods into our quality assurance process to uphold the highest production standards.
What Do AOI and X-Ray Inspection Detect?
AOI (Automated Optical Inspection) is primarily used to inspect the outer and inner layers of printed circuit boards for visible defects. This includes detecting:
  • Solder paste misalignment
  • Component misplacement or polarity issues
  • Open circuits and shorts
  • Solder bridges and tombstoning
AOI systems use high-resolution cameras and image processing software to compare the actual PCB against a digital reference. It’s fast, accurate, and ideal for inspecting surface-mounted devices (SMDs).
X-Ray inspection, on the other hand, is indispensable for analyzing hidden joints and internal structures—especially for BGA (Ball Grid Array) packages, multi-layer vias, and through-hole solder joints. X-ray imaging reveals issues like:
  • Voids in solder joints
  • Insufficient solder fill in plated through holes
  • Misaligned or defective internal layers
Standards and Accuracy in Inspection
High-end PCB manufacturers follow international inspection standards such as IPC-A-610 and IPC-6012 to evaluate solder quality, pad alignment, and defect tolerance. For AOI, detection capabilities can reach down to 01005 components with inspection speeds exceeding 50 cm2/sec. X-ray systems, meanwhile, deliver micro-focus images with resolutions as fine as 5 microns.
Inspection Challenges with Different PCB Types
The number of layers and PCB complexity directly impacts inspection strategy. For instance, multi-layer boards present difficulties in visual verification, making X-ray inspection PCB essential. Fine-pitch components and dense layouts challenge AOI’s ability to differentiate between design anomalies and real defects, requiring frequent calibration and program optimization.
From Detection to Design Improvement
Inspection data is not just for real-time quality assurance—it also feeds back into the design process. At PCBgogo, we maintain traceable records of all detected defects, allowing us to identify recurring issues. This traceability helps customers fine-tune pad sizes, component spacing, and solder mask designs for improved manufacturability.
How PCBGOGO Builds a Reliable Quality Monitoring System
We believe that inspection is more than just a post-process check. It’s an integrated part of our PCB AOI inspection and fabrication workflow. At PCBGOGO, every board goes through:
  • Incoming material inspection
  • Real-time AOI at key manufacturing stages
  • Full-panel X-ray inspection for complex assemblies
  • Data logging and correlation with customer design files
This system enables us to maintain ultra-low defect rates and deliver consistent, high-performance PCBs to our global customers. Whether you're producing multilayer HDI boards or low-volume prototypes, our inspection methods ensure each board meets the standards of a PCB quality test method suitable for mission-critical applications.
Quality is never an afterthought at PCBGOGO—it’s built into every step of your PCB’s journey.
