L****old
Laptops transformers: the pros and cons of choice
2276 0 Apr 23.2019, 19:36:15
The 2 in 1 device combines laptop performance and ultra mobile in a stylish ultra-slim design. Transform your laptop for any tasks - for work and play. Evaluate new features like voice control and face recognition, as well as a new level of performance. 2 in 1 devices with Intel® processors are available in a wide range of elegant, stylish cases and screen sizes, so you can choose the best solution for yourself according to your lifestyle.
Differences transformer from a traditional laptop
The main feature of the new gadget is its very convenient ability to reincarnate. A laptop-transformer can be used as a notebook familiar to everyone, or you can use it at the right moment as a tablet.
When using such a gadget as a traditional laptop, the keyboard is controlled. If necessary, you can easily make a simplified version of a desktop computer from a transformer, if you also connect a mouse to it.
Depending on the possibilities of reincarnation, this type of modern technology can be divided into groups:
The classic version of a laptop-transformer. In this model, the rotation is performed around its own axis, while the keyboard can be used as a convenient stand.
Laptop in the form of a slider. The principle of operation of this version of the transformer is to rotate around the axis of the screen. In this model, the keyboard is folded, making it easily turns into a tablet.
Detachable laptop. A feature of the detachable model is the ability to disconnect the keyboard, which allows you to use the device without it, like a regular tablet.
Among the advantages of the new gadget are the following:
The most important advantage of such a device is a lightweight case.
Permanently connected keyboard that does not need to be charged separately.
Small size, allowing you to carry the device with you almost always.
Design. Transformer laptops have many of the benefits of a new generation of gadgets: slim body, stylish design, ergonomics.
The disadvantages associated with the design features are also present:
Due to the mobility of its elements and a large number of mounts, fragility is inherent in transformer laptops. Therefore, with careless handling, the elements of the device may loosen or even break.
Transformers in their technical characteristics are still inferior to the traditional versions of laptops, this is due to the small size. The smaller the model of such a transformer, the less its performance. Most of the samples on the market have rather weak video cards, which makes it impossible to install any games on them. Naturally, there are devices that have good technical characteristics and performance, but they have a very high cost.
Screen sizes. Most often, gadgets are available with a display of 11 or 13 inches. To replace the tablet such a diagonal is quite enough, but using it as a desktop computer is not very convenient.
Price. High cost is ensured by the fact that the gadget combines two devices at once. Laptop transformer with good performance and performance is a considerable amount.
Connectors The lack of the required number of connectors. For example, without the purchase of an adapter to connect the wired Internet will not work. And to connect a flash card, you will need to disconnect the previously connected device.
The complexity and high cost of repair. If you need to repair such a device, it will probably be much easier to buy a new laptop.
