Mastering Impedance Control for 5G Module HDI PCBs (Sub-6GHz & mmWave)
772 0 Nov 28.2025, 17:56:00
Why Impedance Control Determines 5G Module Performance
As 5G modules move into Sub-6GHz and mmWave (26GHz+) bands, their signal transmission speed easily exceeds 10Gbps. At such high frequencies, HDI PCB impedance control becomes the decisive factor affecting signal integrity.
Industry data shows:
  • When impedance deviation exceeds ±10%, the Bit Error Rate (BER) of 5G signals can increase by 50%.
  • One well-known module manufacturer experienced impedance drifting between 58Ω–65Ω (standard: 50Ω ±5%), resulting in:
    • 22% connection drop rate
    • Failure to pass carrier certification
According to IPC-2141 (High-Frequency PCB Standard), Chapter 6, the impedance deviation for 3.5GHz and 26GHz 5G bands must be ≤±5%.
PCBGOGO has focused on 5G HDI manufacturing for 7+ years, consistently achieving ±3% impedance stability for mass-produced 5G module PCBs.
This article explains the core principles, simulation workflow, and mass-production controls that guarantee 5G signal integrity.
Core Technical Analysis: Multi-Parameter Coordinated Impedance Matching
Effective impedance control for a 5G module HDI PCB requires multi-parameter coordinated matching, combining IPC-2226 HDI design rules with high-frequency signal behaviors.
2.1 Dielectric Constant (εr) Stability
The mmWave 26GHz band is extremely sensitive to εr fluctuations:
  • Every 0.1 change in εr increases impedance deviation by ≈3%.
  • Standard FR-4 (εr fluctuation ±0.3) may cause ±9% impedance deviation, failing 5G requirements.
Recommended Material:
? Rogers RO4350B — εr = 4.4 ±0.05@10GHz
? Loss tangent: 0.0037
? Ideal for 26GHz+ 5G modules
2.2 Trace Width & Spacing Precision
For 5G HDI differential routing:
  • Trace width: 0.12–0.15mm
  • Trace spacing: 0.12–0.15mm
  • Tolerance: ≤±0.01mm
Every 0.02mm deviation in trace width results in ≈5% impedance error, consistent with GB/T 4677 Clause 4.1.
2.3 Layer Thickness Uniformity
HDI stack-up thickness variation must be:
  • ≤±0.005mm
  • A 0.01mm deviation increases impedance error by ≈2%
  • Based on IPC-A-600G Class 3 requirements
Common Target Impedances
Signal TypeTarget ImpedanceApplication
Single-Ended50ΩRF transmission lines
Differential90ΩPCIe 4.0, HS data lines
Using the classical microstrip formula:
Z=60?rln?(5.98hW)Z = \frac{60}{\sqrt{\epsilon_r}} \ln\left(\frac{5.98h}{W}\right)Z=?r60ln(W5.98h)
PCBGOGO HyperLynx simulation confirms that:
  • Rogers RO4350B (εr=4.4)
  • Line width W=0.15mm
  • Dielectric thickness h=0.1mm
→ Achieves 50Ω ±2% impedance accuracy.
3. Implementation Guide: Four-Step HDI Impedance Control Flow
3.1 Step 1 — Material Selection
ItemControl TargetTools/Notes
Base materialRO4350B εr = 4.4 ±0.05Best for Sub-6GHz/mmWave
AlternativeShengyi S1130 (cost-effective)εr = 4.3 ±0.08
Incoming inspectionReject if εr deviation > ±0.05VNA (JPE-VNA-900)
3.2 Step 2 — HDI Stack-Up Simulation (HyperLynx)
Example HDI stack-up: 6-layer 2+2 structure
Signal – Ground – Power – Power – Ground – Signal
Simulation requirements:
  • Layer thickness: 0.1mm ±0.005mm
  • Input measured εr (e.g., 4.42)
  • 50Ω microstrip: W=0.15mm, h=0.1mm
  • 90Ω diff-pair: W=0.12mm, spacing=0.12mm
Simulation pass criteria:
? Impedance deviation ≤±2%
If deviation exceeds ±3%, adjust:
  • h by ±0.005mm
  • W by ±0.005mm
PCBGOGO provides optimized stack-up within 48 hours.
3.3 Step 3 — Routing Execution
  • Enable “trace width lock” in Altium Designer
  • 50Ω single-end: 0.15mm ±0.005mm
  • 90Ω differential:
    • Width: 0.12mm ±0.005mm
    • Spacing: 0.12mm ±0.005mm
  • Differential pair length matching ≤3mm
  • Add clear impedance markers (e.g., “50Ω RF”, “90Ω PCIe”)
3.4 Step 4 — Mass-Production Control
StageControl StandardTools
Lamination180°C ±2°C, 28kg/cm2, 90minLaser thickness gauge
Thickness deviation≤±0.005mmJPE-Laser-800
EtchingEtching factor ≥4:1IPC-TM-650 2.3.17
Trace width accuracy±0.005mmHourly sampling
Final impedance test50Ω: 48.5–51.5Ω, 90Ω: 87.3–92.7ΩJPE-Imp-600
Yield rate: ≥99.5%
3.5 High-Frequency Interference Control (26GHz+ mmWave)
1. Shielding Design
  • Copper pour width ≥0.2mm on both sides of the RF trace
  • Keep ≥0.15mm spacing from signal line
  • Shielding effectiveness ≥40dB @26GHz
  • Tested via IPC-TM-650 2.8.1
2. Via Optimization
  • RF via drill: 0.2mm
  • Via spacing ≥0.5mm
  • Ground-stitch vias around signal via (0.3mm pitch)
  • Via impedance deviation ≤±5%
3. Absorbing Materials
  • mmWave absorber thickness: 0.1mm
  • Absorption rate ≥80% @26GHz
  • PCBGOGO supports automated absorber placement
Conclusion: Reliable 5G Performance Requires End-to-End Impedance Control
5G module HDI PCB impedance control depends on:
  1. Material stability
  2. Accurate simulation
  3. Strict production control
For 26GHz+ mmWave scenarios, shielding and absorber design are essential.
PCBGOGO’s Full-Process 5G HDI Impedance Service includes:
? Material εr measurement report
? HyperLynx precision simulation (≤±2%)
? HDI process control (trace/layer tolerance ±0.005mm)
? 100% impedance testing (yield ≥99.5%)
Future Optimization Trends
  1. 5G HDI + LTCC integration
    • Impedance variation ≤±2%
    • Enhanced stability for mmWave
  2. Impedance-attenuation coupled simulation
    • Predict total transmission performance during the design stage
5G module companies are advised to establish a High-Frequency Impedance Assurance Agreement with PCBGOGO to ensure stable certification performance.
