Flex PCB Cost Guide for Prototypes and Production
15 0 Nov 17.2026, 11:54:00
QUICK ANSWER  Flex PCB cost for a basic one- or two-layer bare board is roughly $5–$45 per piece in a 1–10-piece prototype order, based on PCBgogo's published 2026 planning ranges. The final flexible PCB price depends on the finished outline, layer count, bend requirements, quantity, and added features. Assembly and shipping need separate checks.
A flex tail can solve a tight packaging problem, yet its price depends on how it will be used. A camera module folded once during installation and a wearable hinge flexed every day need different designs. As flex appears in more vehicles, medical devices, and wearables, buyers face this choice more often, according to a 2026 Research and Markets summary. This guide will help you estimate flex PCB cost, understand what affects the price, and prepare the details needed for a useful quote.
Key Takeaways
  • Start with the layer count and finished shape. Both affect how many circuits fit on a production panel.
  • Tell the fabricator whether the board bends once or repeatedly. Bend duty changes material and testing needs.
  • Compare the finished assembly cost when flex removes a cable, connector, or manual assembly step.
How Much Does a Flex PCB Cost?
The table gives a useful starting point for standard one- or two-layer bare flex boards. It cannot price a specific design; a stiffener, fine lines, unusual outline, or rush schedule can move the quote outside these ranges.
Order quantityIndicative bare-board cost per piece
1–10 pieces$5–$45
50–100 pieces$2–$18
1,000+ pieces$1–$9
Planning ranges from PCBgogo's 2026 PCB Cost Guide. Bare board only; final price follows design review.
Why Does Flex Cost More Than Rigid PCB?
Flexible PCB laminate and coverlay cost more to buy and need careful handling. Thin film can wrinkle or shift during imaging, drilling, and lamination; extra layers add alignment and yield risk. Mark Finstad's 2007 Circuitree analysis attributed the price gap to higher material costs and the extra work needed to produce usable flex circuits.
Verified Market Research's 2026 public analysis also describes how small process variations can lower yield and increase scrap or rework during production ramps. Copper and other substrate supply changes can affect lead time and quote stability.
What Affects Flexible PCB Price?
1. Layers and panel fit. More layers add processing steps. A long tab or irregular edge can leave unusable space on a panel. Finstad estimated in his 2007 analysis that layer count plus physical size and shape accounted for about 75% of flex circuit cost in typical builds. Ask for a nesting review before freezing the outline.
2. Bend duty and materials. A static fold may allow a simpler stack-up. Repeated bending can call for different copper, a wider bend radius, and more validation. Specify the bend location, installed shape, and expected cycles so the quote reflects the job.
3. Features and order terms. Stiffeners, coverlay openings, tight trace spacing, heavy copper, special finishes, testing, and expedited production all add work. Quantity spreads setup cost across more pieces, though the price per board still depends on panel yield.
Flex PCB Cost Calculator
Enter your board dimensions, quantity, layers, thickness, copper weight, surface finish, and stiffener requirements on PCBgogo's flexible PCB canculator. Then send your Gerber files and drawing to the sales manager handling your inquiry. PCBgogo can quote your specific design and, if you need a finished assembly, include component sourcing and PCBA in the same inquiry. That gives you a clearer project cost before you place an order.
How to Lower Flexible PCB Cost
  1. Share the bend radius, bend location, and cycle count early. The fabricator can then suggest a stack-up that meets the actual duty without unnecessary layers or materials.
  2. Review panel nesting before locking the outline. A small change to a noncritical tab may let more boards fit on each panel.
  3. Keep stiffeners under connectors and component areas that need support. Check whether a simpler finish, trace width, or copper weight meets the electrical and assembly requirements.
  4. Request prototype and target-volume quotes from the same revision. Compare delivered board cost and the connectors, cables, and assembly labor the flex design may remove.
Flex vs Rigid vs Rigid-Flex Cost Comparison
Board typeBare-board costBest fit
RigidUsually lowestA fixed, flat assembly with enough space for connectors
FlexHigher than comparable rigidA folded or moving interconnect that can replace wiring
Rigid-flexUsually highestRigid component zones joined by built-in flexible sections
For a wearable with a small sensor board linked to a main board, flex may remove a cable and two connectors. Rigid-flex can remove more joints, but its fabrication quote is usually higher. Compare the complete assembly and the expected bend life before choosing.
A lower flex PCB cost starts with a shape that nests well and a stack-up matched to the actual bend. Send PCBgogo your Gerbers, mechanical drawing, quantities, and assembly requirements for a quote you can use to make the decision.
Can I estimate flexible PCB cost before my Gerber files are ready?
Yes. Dimensions, layer count, quantity, and material choices give you a planning estimate. The final price needs the actual files and any bend or stiffener notes.
Should I compare bare-board quotes alone?
Compare the delivered assembly when flex replaces connectors or a cable. Include testing and expected rework if the board will bend repeatedly in service.
