2026 Guide to Panasonic Megtron 6 PCBs for High Speed Design
165 0 Nov 10.2026, 14:50:00
QUICK ANSWER  MEGTRON 6 PCBs are low-loss, high-heat-resistance multilayer boards for channels that cannot tolerate ordinary FR-4 loss. The practical choice depends on the exact R-5775 construction, copper profile, stackup, and channel budget. At 13 GHz, Panasonic lists typical Dk/Df values of 3.34/0.0037 for R-5775(N), not guaranteed 10 GHz values.
Faster SerDes links make laminate selection a first-pass decision. A channel can meet its impedance target yet fail its loss budget when copper roughness and via stubs are modeled loosely.
This guide shows when MEGTRON 6 PCBs are a sensible choice, how to interpret Panasonic data, and what to lock down before fabrication.
What Is MEGTRON 6
MEGTRON 6 is Panasonic Industry's low-loss, high-heat-resistance laminate and prepreg system for multilayer high-speed PCBs. The laminate family is R-5775, paired with R-5670 prepreg, and includes constructions using low-Dk glass, normal glass, or buried-resistor options.
The name alone is not a complete specification. For MEGTRON 6 PCBs, identify the construction, copper profile, finished impedance, and whether substitutions need written approval.
Panasonic MEGTRON 6 Material Properties
Panasonic publishes typical electrical and thermal values by construction and test method. For the common low-Dk-glass R-5775(N), the balanced circular disk resonator value is Dk 3.34 and Df 0.0037 at 13 GHz; Tg is 185 C by DSC, T288 with copper exceeds 120 minutes, water absorption is 0.14%, and peel strength with 1 oz H-VLP copper is 0.8 kN/m.
Searches for "Panasonic MEGTRON 6 dielectric constant dissipation factor 10 GHz" or "Panasonic MEGTRON 6 Dk Df 10 GHz" often surface rounded numbers. Do not relabel 13 GHz data as 10 GHz data. Correlate a broadband model to the selected core, prepreg, resin content, and glass style.
ConstructionDk and frequencyDf and frequencyPractical use
R-5775(N)3.34 at 13 GHz0.0037 at 13 GHzLower-Dk glass option
R-5775(K/G)3.62 at 13 GHz0.0046 at 13 GHzNormal-glass option
Advantages of MEGTRON 6 PCBs
MEGTRON 6 PCBs reduce dielectric loss while retaining the thermal performance needed for complex multilayer assembly. The engineering benefits are practical:
  • Longer channel reach: Lower Df preserves eye height across backplanes, line cards, and server boards.
  • Stable multilayer processing: A 185 C DSC Tg and T288 above 120 minutes provide useful margin for repeated lead-free thermal cycles.
  • More predictable impedance: A defined material family gives the field solver a better input than generic FR-4.
  • Reduced weave sensitivity: The low-Dk-glass construction can help, but routing angle and glass style still need review for tightly coupled differential pairs.
MEGTRON 6 vs MEGTRON 8
MEGTRON 6 is usually the cost-performance choice when its channel model closes; MEGTRON 8 targets materially lower loss for more demanding links. Panasonic lists Dk 3.08 and Df 0.0012 at 14 GHz for the MEGTRON 8 R-5795(U) ultra-low-Df-glass construction, with Tg of 220 C by DMA.
Do not choose by generation number alone. Use MEGTRON 6 PCBs for shorter or moderate-loss channels that retain margin after connector, via, and copper losses are included. Evaluate MEGTRON 8 when long reach, dense routing, 800GbE-class hardware, or a narrow insertion-loss margin makes laminate loss a dominant constraint.
Decision factorMEGTRON 6MEGTRON 8
Typical low-loss dataDk 3.34, Df 0.0037 at 13 GHz for R-5775(N)Dk 3.08, Df 0.0012 at 14 GHz for R-5795(U)
Thermal markerTg 185 C by DSCTg 220 C by DMA
Best fitBalanced loss, availability, and build costMaximum channel margin at higher frequencies
Panasonic MEGTRON 6 Applications
MEGTRON 6 PCBs fit products where channel loss, thermal cycling, and multilayer density must be controlled together.
  • AI servers and supercomputing centers: Accelerator baseboards, switch trays, and high-speed interconnect boards with long differential channels.
  • 5G and 6G infrastructure: Baseband, transport, and radio-support boards carrying high-rate data between processing stages.
  • High-speed automated test equipment: Load boards, interface boards, and probe-card structures where timing and loss repeatability matter.
  • Automotive ADAS: Central compute and sensor-fusion boards that combine high data rates with demanding thermal cycles.
  • Data-center networking: Routers, switches, optical transport equipment, and network interface hardware.
  • Medical imaging and industrial vision: Acquisition boards moving large data streams with low error rates.
Design Considerations for Panasonic MEGTRON 6
A successful MEGTRON 6 PCB starts with a stackup agreed by the designer and fabricator before routing is frozen.
  1. Specify R-5775(N), R-5775(K), or another exact construction; state no substitution when material identity is critical.
  2. Use design Dk from the fabricator's stackup or a validated broadband model, not a single catalog number copied into every layer.
  3. Model copper roughness, plating, solder mask, connectors, and return-path discontinuities. Low Df cannot compensate for a poor via field.
  4. Back-drill long stubs, keep differential transitions symmetrical, and place ground stitching vias beside layer changes.
  5. Define impedance targets and coupons, then confirm pressed dielectric thickness and trace geometry during DFM review.
Simulation Comparison
A useful pre-layout comparison keeps geometry, copper profile, conductor length, and field distribution constant, then changes only the material inputs. For a 100 mm, 50 ohm screening model at 10 GHz, the nearby published Df values can estimate relative dielectric loss before a broadband model is available.
Material inputPublished Df used as proxyNormalized dielectric-loss component
R-5775(N)0.0037 at 13 GHz1.00 baseline
R-5775(K/G)0.0046 at 13 GHzAbout 1.24 times baseline
R-5795(U)0.0012 at 14 GHzAbout 0.32 times baseline
These ratios compare only the dielectric-loss term; they are not predicted insertion-loss values. After routing, replace the proxy with the supplier model and run the full channel, including rough copper, vias, connectors, packages, and receiver equalization.
Turn the Material Choice into a Manufacturable Stackup
MEGTRON 6 PCBs deliver value only when the selected construction, impedance geometry, copper profile, and loss model remain aligned through fabrication. The right decision is the least expensive qualified stackup that still closes the measured channel margin.
What are the Panasonic MEGTRON 6 Dk and Df values near 10 GHz?
For R-5775(N), Panasonic publishes typical Dk 3.34 and Df 0.0037 at 13 GHz using a balanced circular disk resonator. Treat those as nearby reference values, not exact 10 GHz guarantees.
Can MEGTRON 6 replace standard FR-4 without rerouting?
Usually not. The lower Dk changes impedance and propagation delay, so trace width, spacing, dielectric thickness, and timing must be recalculated.
When should a design move from MEGTRON 6 to MEGTRON 8?
Move when the full-channel simulation shows inadequate insertion-loss or eye margin after via and copper optimization. MEGTRON 8 is most valuable when dielectric loss is a major part of the remaining budget.
What files should be supplied for a MEGTRON 6 PCB quote?
Provide fabrication data, drill files, stackup, material code, copper weights, finished thickness, impedance table, back-drill details, and any no-substitution note. Add the channel loss target if engineering review is required.
