HDI PCB Layer Count Price Comparison for Better Quotes
237 0 Sep 22.2026, 14:51:00
HDI PCB Layer Count Price Comparison is best made at a fixed board size, total layer count, material, finish, quantity, and reliability requirement. A 1+N+1 board normally costs less to fabricate than 2+N+2 or 3+N+3 because each extra buildup level adds processing and yield risk. The cheapest board, however, may not be the cheapest finished product if it forces a larger outline or more layers.
Two boards can both have ten copper layers yet receive very different HDI quotes. The difference is often in how those layers are built and connected, not simply the number printed on the drawing. This guide shows how to compare like for like, identify cost drivers, and request a quote that supports a sound design decision.
What HDI Layer Count Actually Means
HDI layer count includes the conventional core and the thin buildup layers added to its outer faces. In 1+8+1, for example, an eight-layer core has one buildup layer on each side, making ten copper layers in total. A 2+6+2 board is also ten layers, but it has two buildup layers per side. The notation describes architecture as well as the total.
Those outer layers are connected with laser-drilled microvias, commonly between adjacent layers. Through holes, buried vias, via-in-pad, and stacked or staggered microvias may also be involved. A designer cannot infer price from the 10-layer label alone because two ten-layer designs may require different lamination, drilling, plating, filling, and inspection sequences. IPC-2226 is the design standard specifically concerned with HDI printed boards; the fabricator must still approve the actual stackup and features.
HDI PCB Layer Count Price Comparison at Ten Layers
For an apples-to-apples comparison, the table holds total copper layers at ten and varies the buildup structure. Its cost ranking is directional, not a price list or a promise that one architecture will work for every layout. A quote also depends on area, quantity, material, surface finish, copper weight, feature size, and testing.
ConstructionBuildup layersRelative fab costUse when
Standard 10 layerNoneLowest if routableConventional vias and board area can meet the routing need
1+8+1One per sideLowest HDI tierOne microvia escape level per side is enough
2+6+2Two per sideHigherA second dense routing level avoids a larger board or more total layers
3+4+3Three per sideHighest of these examplesThe package breakout and outline genuinely need deeper buildup
The comparison does not say that every 3+4+3 board is more expensive than every 2+6+2 board in a different size or volume. It says that, with the other requirements controlled, a deeper buildup typically adds cost. Published generic dollar figures are especially weak for HDI because a small change in microvia placement or fill can change the process route. Ask for alternatives based on the same design data rather than applying a universal percentage markup.
Why Each Buildup Level Changes the Quote
The main cost step in HDI is the added process sequence needed to create and connect another buildup level. Material is only part of the bill. The panel must maintain registration while additional dielectric and copper are laminated, vias are formed and metallized, and fine features are imaged and inspected. A failed operation late in the route has already consumed earlier work, so attainable yield matters to price.
  • Sequential lamination: Each added level can require another controlled press and registration sequence. Thin dielectrics, resin flow, and copper balance affect both yield and finished flatness.
  • Microvia geometry: Laser diameter, dielectric depth, landing-pad size, and via count determine drilling and plating difficulty. IPC guidance and the fabricator's actual process window matter more than a generic minimum on a marketing chart.
  • Stacked versus staggered vias: Stacked structures conserve area but may require copper filling and tighter process control. A staggered path often eases the build when layout space allows it.
  • Via-in-pad and finish: A BGA pad over a via needs an appropriate filled and capped surface for assembly. Surface finish, pad planarity, and inspection should be quoted as part of the same requirement.
  • Qualification and testing: Controlled impedance, microsection coupons, electrical test, and any specified reliability testing add real work. Define acceptance class and evidence required instead of treating a certification logo as the test plan.
Würth Elektronik's published HDI cost training illustrates that construction details, including buried vias and added sequential steps, can move the relative cost even within the same nominal layer count. Use that as a reason to compare complete process routes, not as a substitute for a board-specific quotation.
Choosing the Lowest Cost Structure That Still Routes
The lowest-cost HDI design is the least complex stackup that clears component breakout, signal integrity, power distribution, mechanical limits, and assembly requirements. Start at the dense package rather than at a desired HDI label. Count the escape channels and available routing layers around the BGA, then check whether the rest of the board can carry those connections without excessive detours or added outline area.
If a single outer microvia level frees enough space, 1+N+1 is a sensible first quote. When dense packages on both faces consume additional routing channels, compare 2+N+2 against a larger 1+N+1 board or a higher-layer conventional board. Reserve 3+N+3 and deeper builds for layouts whose density and envelope actually require them. BGA pitch alone cannot determine this choice; pad diameter, pin map, trace rules, via geometry, and available board area also decide the breakout.
Compare total product economics as well as bare-board unit price. A smaller HDI board may reduce enclosure size, connector length, or assembly area, while a difficult stackup may increase lead time or reduce yield. If the layout is not frozen, ask the fabricator to quote two feasible alternatives against one specification. Keep the required impedance and thermal targets unchanged so a lower price does not quietly mean a weaker product.
A Practical Quote Comparison Before Layout Release
A useful HDI quote states the constraints that make the board manufacturable and testable. Send fabrication data and a controlled stackup drawing, then ask the supplier to identify assumptions. A bare "ten-layer HDI" request is too ambiguous to produce a defensible price comparison.
  • Hold the baseline constant: Use the same finished outline, quantity breaks, material class, finished thickness, copper weights, finish, and delivery requirement for each option.
  • Specify the via map: Mark laser microvia spans, buried and through vias, stacked or staggered locations, filled via-in-pad, drill table, and any prohibited structures.
  • State the electrical needs: Include controlled-impedance targets and tolerances, reference planes, critical nets, and any loss or thermal requirements that cannot change.
  • Define acceptance evidence: State the applicable IPC-6012 performance class for a rigid board and request the inspection or test records your application needs. IPC-6016 is superseded, so do not rely on it as a current standalone HDI acceptance callout.
  • Compare delivered cost: Separate tooling or nonrecurring charges, per-board fabrication, electrical test, shipping, expected yield or replacement policy, and prototype versus production quantity.
For example, suppose an eight-layer core with one buildup layer per side fits the footprint, but its outer escape routing needs a wider board. Ask for 1+8+1 at that width and 2+6+2 at the smaller target width, then compare the actual quotations and assembly impact. That is more informative than claiming that 2+N+2 always carries a fixed premium.
How PCBgogo Supports the HDI Price Decision
A quote is useful only if the proposed structure matches the manufacturer's process capability. PCBgogo supports 1+N+1, 2+N+2, 3+N+3, and higher HDI manufacturing, with the exact stackup and feature combination subject to engineering review. This breadth lets a design team compare a simpler buildup against a denser alternative without assuming that a ten-layer count uniquely defines the process.
PCBgogo publishes sequential lamination, stacked and staggered microvias, and via-in-pad capability; its advanced manufacturing page lists production microvias down to 0.10 mm and smaller engineering-reviewed prototypes. These are capability boundaries, not blanket approval for every material, thickness, via stack, or delivery date. The practical advantage is the ability to review the via structure, dielectric thickness, copper distribution, and reliability requirement together before committing the layout.
Send the stackup, Gerbers, drill files, and critical requirements for an engineering review, then compare the feasible structures in a PCBgogo HDI quote. A cheaper 1+N+1 quote is valuable if the routing still works; a 2+N+2 or 3+N+3 proposal earns its cost when it solves a measured density constraint and can be built reliably.
Is a twelve layer HDI board always more expensive than a ten layer HDI board
No. The buildup count, via structure, material, outline, and quantity can outweigh the difference in total layers. A twelve-layer 1+N+1 board may have a less demanding process route than a ten-layer 3+N+3 board, but only comparable quotes can settle the price.
How much more does 2+N+2 cost than 1+N+1
There is no reliable universal percentage. A second buildup level adds processing, but via fill, panel utilization, registration demands, quantity, and testing can dominate the difference. Quote both versions using the same functional and commercial requirements.
Can more core layers be cheaper than more buildup layers
Yes, when extra conventional core routing avoids a sequential HDI step and the added thickness and layer count remain acceptable. The reverse can also be true if HDI reduces the board area enough to offset its fabrication premium. Evaluate both the bare board and the assembled product.
When is 3+N+3 worth considering
Consider it when the package escape and board envelope cannot be solved with fewer buildup levels while preserving electrical and reliability requirements. Review microvia stacking, fill, material, flatness, and test strategy with the fabricator before final routing.
What files produce a trustworthy HDI quotation
Provide Gerbers or equivalent fabrication data, a stackup, drill and via-span details, board outline, quantity, material, finish, controlled-impedance requirements, and acceptance criteria. Flag any alternative structure you want priced so the supplier can identify changes instead of silently altering the design.
Final Decision
Compare HDI prices by construction, not by layer count alone. Hold the functional requirements fixed, request feasible 1+N+1 and deeper-buildup alternatives, and choose the least complex route that meets routing and reliability needs. PCBgogo can review those options from 1+N+1 through 3+N+3 and higher, then quote the design that is actually ready to manufacture.
