IPC-A-610 Standard for PCB Assembly: A Practical Acceptance Guide
62 0 Nov 13.2026, 10:30:00
KEY TAKEAWAYS  The IPC-A-610 Standard gives manufacturers and buyers a shared way to judge the visible workmanship of a finished PCB assembly. Specify the product class before production, inspect placement and solder joints against that class, and define separate tests for hidden joints and electrical function. A board can look acceptable and still fail in use.
A prototype may power up on the bench yet arrive with a reversed connector or a weak solder joint. The costly question is often not whether the board works once, but whether both parties agreed what "acceptable" means. The IPC-A-610 Standard helps settle that question before a batch is built.
Key Takeaways
  • Put the IPC-A-610 revision and Class 2 or Class 3 on the purchase order and assembly drawing; do not leave the class to assumption.
  • Use the standard to judge finished assembly workmanship. Add a separate test plan for electrical performance and hidden solder connections.
  • Supply a complete BOM, polarity markings, approved substitutions, coating map and pass/fail limits so inspection matches the actual product.
What Is the IPC-A-610 Standard?
IPC-A-610 is the visual acceptability standard for completed electronic assemblies, including PCBAs. It distinguishes target conditions, acceptable conditions, process indicators and defects. The applicable revision, product class and customer documentation together determine the inspection decision; a pleasing-looking joint is not automatically required if the specified condition is acceptable.
Its scope matters. IPC-A-610 does not set the assembly process, authorize repair, establish circuit performance or provide X-ray acceptance criteria. J-STD-001 addresses soldering process and end-product requirements when separately specified; bare-board acceptance belongs under the applicable PCB requirements. Keep these documents aligned in the build package.
Which Products Does IPC-A-610 Cover?
The IPC-A-610 Standard covers electronic assemblies through three acceptance classes, not three separate manufacturing methods. The customer should choose the class from the product's reliability needs and service environment.
ClassProduct typePractical selection cue
Class 1General electronic productsFunction is the primary requirement; typical low-consequence consumer devices.
Class 2Dedicated service productsContinued performance and long life are expected; interruption is undesirable.
Class 3High-performance productsContinued performance or performance on demand is critical; downtime may be unacceptable.
Key IPC-A-610 Acceptance Checks for a PCBA
Start with the assembly drawing and BOM, then compare the physical board with the specified IPC-A-610 class. Check for missing or incorrect components, damage, loose hardware, exposed conductors where protection is required, and visible contamination. Record the reference designator and photograph any disputed condition so engineering can make a repeatable disposition.
Do not treat every cosmetic difference as a defect. A process indicator calls for process attention but does not automatically mean rejection. Conversely, a board that passes a power-on check may still have an unacceptable solder bridge or damaged insulation.
Component Placement Requirements
Placement inspection asks whether each part is present, correctly oriented and mechanically secure, with leads or terminations properly aligned to their lands. Compare polarized capacitors, diodes, IC pin 1 and connector keying with the drawing, not only the silkscreen. Check that shifted parts do not compromise the solder connection or required clearance.
For a prototype, mark no-populate positions and approved alternatives explicitly. This prevents a deliberate omission from being reported as a missing component and keeps first-article inspection useful when the design changes.
IPC-A-610 Soldering Requirements
The IPC-A-610 Standard evaluates the finished solder connection: wetting, joint geometry, bridging, exposed base metal, disturbed joints and damage are judged by the relevant component style and class. Surface-mount chip parts, gull-wing leads and through-hole pins have different criteria; a single "good fillet" rule is unsafe.
Inspect the joint from the accessible views and use the standard's written criteria for the exact condition. If a BGA or bottom-terminated component hides the joint, plan X-ray or another agreed method separately. A shiny joint alone does not prove sound wetting, and a dull lead-free joint is not automatically defective.
Cleaning and Coating Requirements
Cleaning inspection looks for harmful residues, foreign material and damage left by the process. Agree on cleaning requirements before assembly, especially around fine-pitch parts or high-impedance circuits. Visual cleanliness cannot establish ionic contamination levels, so request a suitable cleanliness test if that risk matters.
Where conformal coating is specified, supply a coating drawing with keep-out zones for connectors, test points and heat-transfer surfaces. Inspect coverage, adhesion and unwanted coating in prohibited areas against the agreed requirements. The IPC-A-610 Standard does not make coating mandatory for every PCBA.
Inspection and Testing Requirements
The IPC-A-610 Standard supports visual workmanship inspection; it is not a complete test specification. A practical release plan adds the checks needed to find defects that eyesight cannot reveal.
  • First article: verify BOM values, orientation and placement before the full run.
  • SPI and AOI: screen paste deposition and visible placement or soldering faults; review machine calls against the agreed class.
  • X-ray: examine hidden BGA or QFN joints under separately agreed criteria.
  • Electrical and functional test: define continuity, power limits, firmware, loads and pass/fail thresholds in a customer-approved procedure.
Keep inspection results and test records tied to the board revision. That makes a prototype finding actionable before the same error reaches production.
Mass PCBA produced by PCBgogo in accordance with IPC-A-610 standard
PCBgogo PCB Assembly to IPC-A-610 Requirements
PCBgogo supports IPC-A-610 Class 2 and Class 3 assembly for prototypes through production orders, starting at one board. Its integrated PCB fabrication, component sourcing and SMT, through-hole or mixed-technology assembly reduce the handoffs that can obscure a build requirement. Expedited assembly may be available once parts and files are ready; confirm the schedule during quotation.
The published assembly workflow includes automated placement, solder-paste inspection, AOI, visual QC and X-ray for hidden joints. PCBgogo also offers customer-defined functional testing. These controls go beyond visual acceptance alone, but they do not replace a project-specific test plan. Drawing on extensive experience across consumer electronics, industrial, medical, automotive, and aerospace applications, we use a rigorous, multi-stage testing process to deliver high-quality PCB assemblies to our customers.
Send PCBgogo the Gerbers, BOM, pick-and-place file, assembly drawing, chosen IPC-A-610 revision and class, and any coating or test instructions. Ask for the first-article and final inspection evidence your product needs before releasing the production quantity.
Does IPC-A-610 Class 3 apply to every industrial PCB?
No. Class 3 fits products where continued high performance or performance on demand is critical. Select the class from the application and document it in the order.
Does IPC-A-610 require X-ray or functional testing?
No. Its visual criteria do not define X-ray acceptance or functional pass limits. Specify those methods and limits separately for hidden joints or product behavior.
Can a PCB assembly pass electrical test but fail IPC-A-610 inspection?
Yes. Electrical testing may miss a mechanically weak joint, wrong hardware or visible contamination. Use both checks where the risk warrants them.
