PCB Cost Breakdown: How Much Is a PCB from Prototype to Assembly?
10 0 Nov 16.2026, 18:20:00
QUICK ANSWER  A useful PCB cost breakdown separates the bare board from components, assembly, testing, and shipping. A simple two-layer FR-4 prototype may be roughly $1–$10 per bare board in a small batch, but size, quantity, finish, and lead time change the quote. For a populated board, the bill of materials and setup often matter more than the laminate.
A prototype quote can look cheap until the stencil, parts, inspection, and freight appear. If you are asking "how much is a PCB?", first decide whether you need an empty board or a tested assembly. The same design can have very different unit costs at five pieces and 500 pieces.
Key Takeaways
  • Compare like with like: Hold the Gerbers, stackup, finish, quantity, test scope, and delivery date constant when comparing prices.
  • Separate fixed from variable cost: Tooling and setup spread over the order; material, parts, placement, and yield scale with each board.
  • Optimize the whole build: A cheaper bare board is no saving if it increases assembly defects or field failures.
What Drives the PCB Price?
The eight factors below explain most differences in a PCB cost breakdown. Ask which specification triggers each charge before redesigning anything.
1. Base material. Standard FR-4 is the default for many rigid boards. Higher-performance laminates cost more because of material price, processing requirements, or both. Choose by the circuit's electrical, thermal, and mechanical needs:
MaterialRelative CostWhen It Earns Its Cost
Standard FR-4Lowest baselineGeneral rigid electronics
High-Tg FR-4HigherRepeated reflow or thermal cycling
Rogers RF laminateHigher; grade dependentControlled RF loss and dielectric behavior
Polyimide flexHigherBending or compact interconnects
Metal-coreHigherHeat spreading in power or LED designs
2. Layers and complexity. More copper layers add imaging and lamination steps. Fine traces, tight impedance tolerance, heavy copper, and unusual stackups raise process control demands. Keep the layer count that the routing and signal integrity actually require.
For example, a controller with a noisy switch-mode supply and sensitive analog inputs may justify four layers for continuous reference planes. Forcing it onto two layers to lower the fabrication line item can increase layout time and make EMC or noise problems harder to resolve.
3. Size and panelization. Larger outlines consume more laminate. Panelization places multiple boards on one production panel, spreading handling and setup across more units. Fit as many usable boards as practical, but leave room for rails, tooling holes, depaneling, and the assembler's equipment; maximum packing density is not always maximum yield.
4. Hole types. Standard through-holes use established drilling and plating. Blind or buried vias, laser microvias, and filled via-in-pad add process steps; use them only where routing or package pitch requires them.
5. Finish and special processes. ENIG offers a flat solderable surface for fine-pitch parts, while standard HASL may suit less demanding assemblies. Edge plating, controlled impedance verification, and other special requirements should have a design reason.
6. Quantity. A five-board prototype carries setup across five units; a production batch spreads it further. Order only after validating the design, because a cheaper unit price does not compensate for obsolete inventory.
7. Lead time. Rush work can require dedicated capacity or schedule changes. Quote a normal lead time as the baseline, then pay for speed only when it protects a real milestone.
8. Testing. Bare-board electrical testing checks opens and shorts. Assembly-level inspection or functional test adds labor, fixtures, and programming, but can catch faults before installation. Specify the acceptance and test scope on the RFQ.
How to Estimate PCB Assembly Cost
For a populated board, estimate total order cost as fabrication + components + assembly + setup + test + shipping, then divide by the number of accepted boards. A quote that omits components or freight cannot answer "how much is a circuit board?" in its finished, usable form.
Consider a pilot run of 100 four-layer control boards. The figures below are an illustrative budget, not a PCBgogo quote; use your BOM and current supplier prices for a real decision.
Cost Item100-Board Pilot
Bare boards$300
Components$900
Stencil and setup$120
Placement and soldering$250
Inspection and test$80
Shipping$50
Total / cost per accepted board$1,700 / $17
Here, changing the bare-board price by 10% moves the total by only $30. A missing component, extra setup, or low assembly yield could matter more. Ask for an itemized quote and confirm whether tooling, test fixtures, scrap allowance, taxes, and freight are included.
Send the assembler a complete BOM with manufacturer part numbers and approved alternates, plus Gerbers, drill files, centroid data, and an assembly drawing. Missing polarity or placement information can turn a quick estimate into an engineering clarification and delay the build.
How to Lower Assembly Cost Without Weakening the Design
Start with choices that reduce handling and sourcing work: consolidate equivalent BOM line items, use available parts, keep components on one side when practical, and panelize small boards for automated assembly. Do not remove test coverage or switch finishes merely to hit a target price. For a deeper design-stage checklist, see PCBgogo's PCB cost and reduction guide.
Where PCB Assembly Costs May Move Next
Component availability and product complexity will keep finished-board budgets less predictable than bare-board budgets. Smaller packages and dense routing can move a design toward HDI, filled vias, or flatter finishes; high-mix, short-run orders keep setup visible. Recheck the BOM and fabrication assumptions at each design revision instead of carrying forward last quarter's unit cost.
A sound PCB cost breakdown identifies the specifications that earn their price and the fixed charges that shrink with volume. To price your actual design, compare fabrication and assembly options in PCBgogo's instant quote, then upload the Gerbers and BOM for review before committing to production.
How much is a PCB for a prototype?
A basic two-layer FR-4 bare board in a small prototype batch may be roughly $1–$10 per board; size, finish, turnaround, and shipping can change the total. Request the exact configuration rather than treating a headline price as a delivered price.
How much is a circuit board after assembly?
Add the BOM, stencil and setup, placement, inspection, test, and freight to the bare-board quote. The illustrative 100-board pilot above totals $17 per accepted assembly, but your component list and yield determine the actual figure.
Does a four-layer PCB always cost more overall than a two-layer PCB?
The bare four-layer board usually costs more. Yet if the extra planes reduce board area, assembly difficulty, or signal-integrity rework, the finished product may cost less; compare complete builds.
