Potentiometer Wiring for PCBs: A Practical Design Guide
52 0 Nov 13.2026, 12:00:44
QUICK ANSWER  Potentiometer wiring depends on the job: connect both outer terminals across a reference and take the wiper to a high-impedance input for adjustable voltage, or use the wiper and one outer terminal for variable resistance. On a PCB, verify the pinout, wiper load, power rating, and ADC input requirements before routing or assembly.
A control that works on a breadboard can reverse direction or make an ADC reading flicker after assembly. Often the cause is a mismatched footprint, loaded wiper, or noisy route. These checks make potentiometer wiring a repeatable PCB design decision.
What Is Potentiometer Wiring?
Potentiometer wiring connects a resistive track and its moving contact, the wiper, to the circuit. The two outer terminals span the full nominal resistance; the wiper divides that track into two resistances whose sum is approximately the end-to-end value. Rotation direction and terminal numbering are part-specific, so confirm them from the datasheet and with an ohmmeter before assigning nets.
With power off, measure between the outer terminals: the reading should stay nearly constant as you turn the shaft. Then measure from the wiper to either end; one reading should rise while the other falls. This identifies the wiper even when a drawing shows an unexpected view.
B1K 1K rotary potentiometers
Two Basic Potentiometer Wiring Modes
The two useful modes are a three-terminal voltage divider and a two-terminal rheostat. Choose the mode from what the next circuit needs: a voltage or a change in resistance.
ModeConnectUse it forCritical check
Voltage dividerOuter ends to reference and ground; wiper to inputADC setpoint, bias, level controlInput must not heavily load the wiper
RheostatWiper and one outer end in series with the circuitCurrent or resistance adjustmentCheck worst-case current at minimum resistance
For a 10 kΩ linear pot across 3.3 V, the track draws 0.33 mA and dissipates about 1.1 mW. An unloaded center wiper sits near 1.65 V. The wiper source resistance peaks near mid-travel at about 2.5 kΩ; a low-impedance load pulls the output away from the expected ratio. If an ADC cannot settle with that source resistance, use a suitable buffer or adjust its acquisition time according to its datasheet.
In rheostat mode, tying the wiper to the unused outer terminal can give the circuit a full-track path if the wiper loses contact. Do not assume this makes a failed control safe: assess the resulting circuit state. Never connect a potentiometer directly across a supply as a two-terminal rheostat without a current-limiting path.
Potentiometer Types and Their Wiring Implications
Physical format determines mounting; taper determines resistance change with travel.
TypeBest fitPCB implication
RotaryUser-adjusted panel controlCheck shaft orientation, support, and pin view
SlideVisible position settingCheck travel clearance and slot dimensions
TrimmerOccasional board calibrationKeep screwdriver access after assembly
DigitalSoftware-controlled adjustmentCheck terminal voltage and wiper-current limits
A linear taper gives roughly proportional resistance change; an audio taper suits loudness control. Neither label tells you the pin order. Digital resistor terminals usually must remain within the device supply rails, even if the control interface uses another voltage.
How to Choose the Right Potentiometer
Select a potentiometer by the circuit it must drive, then by the user interface and footprint. Work through these checks before locking the BOM.
  • Resistance and loading: make the divider current comfortably larger than the input leakage and load current, while staying within your power budget. Recalculate the actual wiper voltage with the connected load.
  • Power and wiper current: calculate track dissipation from the applied end-to-end voltage and check the datasheet rating. In rheostat mode, evaluate current at the lowest available resistance.
  • Taper, travel, and tolerance: choose linear for predictable setpoints; use the specified taper for the human control response. Add a calibration step if absolute position matters.
  • Mechanical fit: verify the footprint from the recommended land pattern, including view direction, body outline, shaft or tool access, and mounting loads.
For potentiometer wiring into an ADC, compare worst-case source resistance with the ADC's acquisition-time guidance. This often matters more than nominal resistance tolerance.
Potentiometer Wiring and PCBA Troubleshooting
Troubleshoot potentiometer wiring from the physical pins toward the receiving circuit. Start with power off; then apply a current-limited supply for voltage checks.
1. Confirm the assembled part and orientation against the BOM, footprint, and datasheet. A top-view drawing interpreted as a bottom view can swap the outer terminals.
2. Measure end-to-end resistance and each wiper-to-end resistance while moving the control. An open, erratic, or unchanged reading points to a wrong pin, solder joint, or damaged track.
3. In divider mode, measure both outer-terminal voltages and the wiper voltage. A fixed wiper suggests a short or wrong net; a compressed range suggests load or reference problems.
4. If the meter looks stable but ADC readings jump, inspect ground return, nearby switching traces, sampling time, and input filtering. Put any filter capacitor near the ADC input and verify its settling behavior.
For a reversed knob response, swap the outer-terminal nets in the next revision; keep the wiper net. Add labeled test points for both ends and the wiper on prototypes.
Advanced Potentiometer Wiring Techniques
Advanced potentiometer wiring keeps the adjustable signal accurate under real loading and noise. A unity-gain buffer after the wiper isolates a divider from a demanding ADC or downstream stage, provided the amplifier's input and output ranges cover the full setting. A small input filter can suppress noise, but its resistor and capacitor must allow the ADC input to settle between samples.
For a remote panel control, route the wiper beside a quiet return, keep it away from switching nodes, and connect the reference and ground to the same clean analog domain used by the measurement. If a broken wiper must produce a defined result, add a weak bias at the receiving input and test the open-circuit behavior rather than assuming it will fail predictably.
Prototype the exact footprint and analog front end. Use PCBgogo's quick-turn PCBA assembly service to test the advanced configuration, then check wiper range, noise, and control direction before approving the layout.
Which potentiometer pin is the wiper?
The wiper is the moving contact, often the center pin on a three-pin mechanical part. Confirm with the datasheet or by measuring which pin changes resistance to both ends as the shaft moves.
Can I swap the two outer pins?
Yes, in a simple voltage divider this reverses which way the output rises as you turn the control. It does not change the end-to-end resistance.
Why is my ADC value unstable even when the wiper voltage looks steady?
A meter averages a slowly changing signal, while an ADC samples it briefly. Check source resistance, acquisition time, ground noise, and any input filter against the ADC datasheet.
Can a potentiometer control an LED directly?
A small signal potentiometer is usually a poor direct current control for an LED. Use a current-limited driver or transistor stage, and keep wiper current within the part rating.
