Reflow Solder Guide: Process, Paste Selection and Fixes
852 0 Sep 04.2026, 16:26:00
KEY DEFINITION  Reflow soldering refers to joining electronic components to a printed circuit board by heating pre-applied solder paste until its alloy melts, wets the pads and terminations, and solidifies during cooling. Reliable results depend on paste selection, accurate printing, a measured thermal profile, and inspection.
A board can look correctly assembled yet contain weak or bridged joints. Understanding the full reflow solder process helps engineers prevent these failures before they become rework, production delays, or field returns.
What Is Reflow Solder?
Reflow soldering is a core assembly method for surface-mount technology (SMT), including chip resistors, QFNs, and ball grid arrays (BGAs). It forms electrical and mechanical connections across many joints in one heating cycle. Bare PCB fabrication creates pads and interconnects; reflow joins components to those prepared surfaces.
Types of Reflow Soldering and Their Uses
Reflow methods differ mainly in how they deliver heat. Equipment selection depends on board geometry, thermal uniformity, and production needs.
MethodHeat sourcePractical consideration
ConvectionCirculating hot air or nitrogenSupports repeatable SMT production with mixed component sizes
InfraredRadiant energyAbsorption differences and component shadowing can affect heating
Vapor phaseCondensing heated vaporHeating is limited by the process fluid's boiling temperature
This resource explains how condensation transfers heat across the assembly. Local hot-air tools also provide targeted heating for component rework.
How Heat Creates a Reliable Solder Joint
Reflow soldering activates flux to remove oxides, melts the alloy to wet the joining surfaces, and then cools the solder into a solid connection. Preheating limits thermal stress. A soak, when specified, helps equalize temperatures and manage volatile release. During reflow, molten solder spreads over solderable surfaces; controlled cooling lets joints solidify without disturbance.
A typical reflow profile has four stages: preheat, soak, reflow, and cooling. For certain SAC/Innolot solder paste formulations, a peak temperature of 235–250°C and a soak time of 60–120 seconds can serve as starting points. These values are formulation-specific, so validate the final profile against the requirements of the solder paste, components, and PCB.
Oven setpoints are not joint temperatures. Measure the hottest and coldest locations on a representative populated board with thermocouples before approving production.
How to Choose Solder Paste
Select solder paste by alloy, powder size, flux chemistry, and handling requirements.
  • Alloy: SAC305 is a common lead-free choice. Match the alloy to component finishes, service conditions, and allowed heat exposure.
  • Powder size: Type 4 and Type 5 refer to solder powder particle size, not alloy composition. Choose a powder that prints reliably through the stencil’s smallest apertures. Type 5 has finer particles than Type 4, but its greater surface area relative to volume also increases oxidation sensitivity.
  • Flux: Water-soluble residues require cleaning. No-clean residues may remain when the application's cleanliness and coating requirements permit.
  • Handling: Follow the supplier's storage limits and working life. Allow refrigerated paste to reach room temperature while sealed before opening.
Reflow Solder Process from Printing to Inspection
The reflow solder process connects five operations, with checks before and after heating.
  1. Review the build: Confirm footprints, polarity, surface finish, stencil openings, and component thermal limits. Follow moisture-sensitive component handling instructions.
  2. Print the paste: Align the stencil and deposit controlled volumes. Solder paste inspection (SPI) checks deposit volume, height, and position before defects enter the oven.
  3. Place components: Verify orientation and alignment. Paste tack holds parts until soldering; self-alignment cannot reliably correct major placement errors.
  4. Run the validated profile: Preheat gradually, use the paste's specified soak or ramp approach, maintain suitable time above liquidus, and cool within approved limits. Liquidus is the temperature above which the alloy is fully liquid.
  5. Inspect and test: Automated optical inspection (AOI) checks visible defects; X-ray evaluates hidden BGA/QFN joints. Electrical or functional testing checks operation. Clean residues when required by the selected process.
Common Reflow Defects and Practical Fixes
Reflow defects can stem from solder paste printing, component placement, materials, or heating conditions. Identify the root cause before adjusting oven settings, as temperature changes alone may not resolve issues originating earlier in the process.
  • Bridging: Excess paste or misalignment connects adjacent pads. Check stencil apertures, print registration, and placement accuracy.
  • Tombstoning: Unequal wetting forces lift one end of a chip component. Balance paste deposits, pad thermal connections, and heating.
  • Poor wetting or open joints: Oxidation, exhausted flux, or insufficient heat prevents bonding. Check solderability, paste condition, and measured joint temperatures.
  • Voiding: Trapped gases leave cavities. Review paste formulation, thermal-pad stencil design, and the profile; use X-ray to evaluate results against product requirements.
  • Solder balls: Paste spatter or contamination leaves loose particles. Check paste handling, print quality, and excessive heating rates.
For BGA head-in-pillow defects, the ball and paste fail to merge. Investigate package warpage, flux activity, and solderability instead of assuming that extra heat will solve the problem.
How PCBgogo Supports Reflow from PCB Fabrication to Inspection
PCBgogo connects PCB manufacturing with assembly controls that address these upstream causes of soldering defects.
  • Board construction: Our FR4 manufacturing capabilities include multilayer builds and Tg 130, 150, and 170 options. Match the laminate and stackup to the assembly's thermal demands. Tg describes the glass transition temperature, not a maximum reflow temperature; evaluate the laminate's complete thermal performance.
  • Solderable surfaces: Our advanced fabrication services include ENIG for flat fine-pitch soldering surfaces and resin filling for planar via-in-pad structures, supporting dense BGA/QFN layouts.
  • Process inspection: Our assembly capabilities include full-coverage SPI, AOI, and X-ray inspection for components with hidden pads. These checks help identify printing and soldering issues at relevant stages.
  • Flexible production: Assembly orders start from one piece, with component sourcing and customer-specified functional testing available. This supports prototype validation before scaling production.
Reliable reflow solder joints start with compatible materials, controlled paste deposits, and a measured thermal profile. Combine those controls with suitable PCB fabrication and inspection to reduce avoidable rework.
FAQ About Reflow Soldering
How does reflow differ from wave soldering?
Reflow melts paste already deposited on the board and is widely used for SMT. Wave soldering passes the board over molten solder and commonly serves through-hole assembly.
Is 260°C the correct reflow temperature?
No universal peak temperature suits every assembly. Use the solder paste's process window and each component's thermal limits, verified on the actual board.
Can both sides of a PCB be reflowed?
Yes, double-sided SMT assemblies commonly use separate passes. Plan component retention and verify that parts and materials tolerate the cumulative thermal exposure.
Does reheating always fix a bad joint?
No. Rework must address causes such as contamination, insufficient solder, or poor contact; repeated heating alone can damage the assembly.
Does no-clean paste always eliminate washing?
Not always. No-clean solder paste can eliminate post-soldering cleaning in a qualified process. However, if conformal coating is required, compatibility between the coating and remaining flux residues must be verified before cleaning can be omitted.
