Rigid Flex PCB Assembly Guide for Reliable Production
110 0 Oct 30.2026, 16:14:00
KEY DEFINITION  Rigid flex PCB assembly mounts and solders components on a board that combines rigid support with integrated flexible interconnects. Reliable production depends on controlled handling, full-area tooling, a measured reflow profile, protected bend zones, and electrical plus mechanical testing matched to the final installation.
A rigid-flex board can remove cables and connectors, but it cannot tolerate casual handling. In rigid flex PCB assembly, a creased flex area, unsupported stencil print, or unverified reflow profile can create an intermittent failure.
This guide explains how to plan, assemble, inspect, test, and quote the build.
What Is Rigid Flex PCB Assembly
Rigid flex PCB assembly is the process of attaching components to a continuous circuit that combines rigid FR-4 sections with flexible polyimide sections. Components normally sit on rigid or stiffened areas; flex sections route signals and power through folds or moving joints.
One assembly can replace several boards, harnesses, and connectors. In return, the fabricator and assembler need the stack-up, bend lines, installed shape, stiffener details, and static or dynamic flex requirement.
Comparing Standard Flexible and Rigid Flex PCB Assembly
The three assembly types use similar soldering equipment, but their support and failure risks differ.
AttributeStandard Rigid PCBFlexible PCBRigid-Flex PCB
Base structureRigid laminatePolyimide flexFR-4 and polyimide in one build
Assembly supportPanel rails often sufficeDedicated carrier requiredCarrier supports rigid islands and flex spans
Main process riskWarpage and solder defectsStretching, curling, and heat damageTransition stress, moisture, and uneven thermal mass
Cost focusLayer count and component loadTooling and stiffenersStack-up, tooling, forming, inspection, and yield
A standard SMT line can perform rigid flex PCB assembly after tooling, profiling, inspection, and work instructions are adapted.
Rigid Flex PCB Assembly Challenges
The main rigid flex PCB assembly challenges come from combining a dimensionally stable rigid section with thin, moisture-sensitive flex material. Four controls matter most:
  • Flat support: Support printing, placement, transport, and reflow without forcing the installed bend into the panel.
  • Protected transitions: Keep components, vias, and tooling contact clear of the rigid-to-flex transition unless reviewed for that load.
  • Moisture control: Know the storage history. When drying is required, follow the material specification instead of improvising a hot bake.
  • Controlled strain: Lift the panel by supported rigid areas and never fold a static-flex zone repeatedly during inspection.
Put these controls in the traveler and operator instructions.
The Complete Rigid Flex PCB Assembly Process
A complete rigid flex PCB assembly process links incoming inspection to a verified installed shape. Each stage should have a measurable acceptance point before the lot moves forward.
  • Incoming quality control and surface cleaning. Confirm the revision, stack-up, finish, stiffeners, BOM, date codes, and moisture records. Inspect coverlay openings and transitions. Use material-compatible cleaning, and dry only when the handling specification requires it.
  • Solder paste printing and component placement. Use a carrier that supports every rigid island and flex span. Verify stencil alignment, paste release, polarity, and first-article placement. Keep nozzles and clamps off exposed flex zones.
  • Reflow soldering. Profile the actual panel for the selected paste. Place thermocouples on a high-mass area, a small joint, and near a flex transition. Cool the board while supported, then use AOI and X-ray for hidden joints.
  • Stiffener connector and through-hole assembly. Control adhesive thickness, alignment, cure, and connector insertion force. Selective or hand soldering must limit local heat. Add strain relief before mating or forming.
  • Electrical and mechanical testing. Combine visual inspection with continuity, flying probe or in-circuit test, and functional test as risk warrants. Verify dimensions and the installed fold. Bend only to the defined radius and angle; do not cycle a static installation.
Factors That Affect Quality Reliability and Cost
Rigid flex PCB assembly quality, reliability, and cost are set largely before the first component is placed. Review these factors together rather than optimizing the assembly price in isolation.
  • Bend geometry: Define static or dynamic use, bend direction, radius, angle, and cycle expectation on the mechanical drawing.
  • Component location: Keep heavy parts, connectors, vias, and test pads away from bends and transitions. Stiffeners must spread insertion force.
  • Panel and tooling design: Stable rails, fiducials, tooling holes, and a carrier reduce print variation and handling damage.
  • Thermal compatibility: Finish, laminate, adhesives, solder paste, and component limits must tolerate one thermal process.
  • Inspection and test coverage: Use AOI for visible defects, X-ray for hidden joints, and electrical or functional tests for faults appearance cannot reveal.
A disciplined rigid flex PCB assembly plan adds tooling and test cost but reduces rework and avoidable field failures.
Rigid Flex PCB Assembly Applications
Rigid flex PCB assembly is most useful when packaging space, vibration, weight, or connector reliability matters more than the lowest bare-board price. Common applications include:
  • Medical instruments: Monitors, imaging heads, and wearables use folded interconnects where cable access is limited.
  • Automotive modules: Cameras, lighting, steering controls, and sensors benefit from fewer vibration-prone connectors.
  • Aerospace electronics: Navigation, sensing, and communication assemblies reduce wiring mass and connection points.
  • Robotics and industrial equipment: Moving sensors require defined bend behavior, strain relief, and service-aware routing.
  • Consumer wearables: Smartwatches, earbuds, and cameras fold boards around batteries, displays, and enclosures.
The application environment should set the material, bend classification, test plan, and acceptance level.
Get a Quote for Rigid or Flexible PCB Manufacturing and Assembly
An accurate rigid flex PCB assembly quote requires more than Gerber files and a BOM. Submit fabrication data, centroid data, drawings, stack-up, impedance requirements, bend lines, radius and angle, stiffener data, panel preference, sourcing method, test requirements, and volume.
For rigid flex PCB assembly, PCBgogo supports rigid-flex manufacturing and PCBA in one coordinated workflow, including component sourcing, SMT and through-hole assembly, AOI, X-ray inspection, and electrical testing. Request a DFM review so tooling, forming, test access, and assembly risks are resolved before materials are committed.
Summary
Reliable rigid flex PCB assembly treats the flex section as a controlled mechanical part of the circuit. Clear bend data, supported processing, measured reflow, protected transitions, and risk-based testing enable repeatable production.
Can Components Be Mounted on the Flexible Area
Yes, when the flex area is designed and stiffened for support. In most rigid flex PCB assembly projects, rigid-island placement lowers solder-joint strain and simplifies tooling.
Does a Rigid Flex Board Need a Dedicated Reflow Profile
Yes. Measure the actual rigid flex PCB assembly because its thermal mass is uneven. The solder paste sets the process window; thermocouples show how the board reaches it.
What Is the Difference Between Static and Dynamic Flex
Static flex bends mainly during installation; dynamic flex cycles in service. Dynamic rigid flex PCB assembly therefore needs tighter control of copper type, trace direction, bend geometry, strain relief, and life testing.
How Can Rigid Flex PCB Assembly Cost Be Reduced
Stabilize the stack-up, bend geometry, panel, BOM, and test plan before ordering. Early DFM review prevents tooling changes, low-yield panels, unnecessary tests, and avoidable substitutions.
