Shortage of Raw Materials in PCB Manufacturing 2026 Guide
568 0 Oct 06.2026, 17:45:00
KEY TAKEAWAYS  A shortage of raw materials in PCB manufacturing is concentrated in copper, low dielectric glass cloth, low profile foil, and advanced laminates. Standard FR 4 is generally obtainable, but exact constructions can still face delays. Early stackup approval, controlled alternatives, and material reservation are the best protection.
A PCB schedule can look secure until a laminate is unavailable, a replacement changes impedance, or copper pricing expires. A shortage of raw materials is therefore an engineering and scheduling problem, not only a purchasing issue.
This guide covers the 2026 timeline, standard FR 4 versus M6 to M8 systems, project impact, and practical action.
2026 Raw Material Shortage Timeline and Whether It Will Continue
The 2026 shortage of raw materials is a sequence of material-specific risks. Copper remains sensitive to mine and smelter disruptions, while advanced glass cloth and very low profile foil are pulled toward AI server programs.
PeriodSupply signalProject response
January to March 2026Copper rose amid supply concerns and mine disruptions. High-end allocation stayed tight.Confirm copper weight, thickness, and laminate family before quoting.
April to June 2026The World Bank forecast copper prices about 21 percent higher for 2026.Reserve qualified material and avoid late stackup changes.
July to September 2026Some capacity improved, but qualification queues and uncommon glass styles constrained supply.Check core, prepreg, glass style, foil profile, and quantity.
October to December 2026Standard materials remain more flexible than advanced systems.Use a rolling forecast and approve alternates early.
First half of 2027Copper may ease, while AI demand keeps pressure on low-loss inputs.Maintain two qualified material paths.
The shortage of raw materials should improve only in parts. The World Bank expected copper prices to decline about 8 percent in 2027, but data center, electrification, and transport demand to remain solid. Narrow bottlenecks can persist after broad price pressure eases.
Raw Materials Facing the Greatest Pressure
The shortage of raw materials is most severe where commodity risk meets a specialized electronics process.
MaterialPressurePCB exposureVerify before ordering
Low dielectric glassVery highFew qualified sources serve ultra-low-loss laminates.Glass style, resin content, Dk and Df method
HVLP and VLP copper foilHighSmooth foil needs dedicated treatment and qualification.Profile, weight, peel strength, permitted source
Copper and ED foilHigh price riskUSGS estimated U.S. refined copper output fell 9 percent in 2025.Quote validity, surcharge, finished copper
High-speed CCL and prepregHigh for exact buildsResin, glass, foil, and thickness must form one qualified system.Part codes, tolerance, lead time, reserved lot
Finish metals and chemicalsMediumCost and compliance can change while laminate remains available.Finish thickness, compliance, price validity
A shortage of raw materials is worse when a drawing fixes an uncommon combination without identifying critical attributes. Separate functional requirements from preferred codes.
Treat each shortage of raw materials notice as a part number and construction issue, not a market rumor.
Why Raw Materials Become Short
A shortage of raw materials develops through connected constraints, and each one needs a different response.
  • Mining and refining disruptions: Lower ore grades, maintenance, weather, or transport interruptions can reduce copper output.
  • Concentrated capacity: Specialized glass, resin, and foil equipment means one input can limit a laminate family.
  • AI and networking demand: Accelerators, switches, optical equipment, power hardware, and backplanes use the same material pool.
  • Long qualification cycles: Available material may remain unusable until signal integrity, CAF, thermal, flammability, and reliability evidence is approved.
  • Trade and logistics changes: Tariffs, controls, customs, and freight can create a regional shortage of raw materials without lowering global output.
  • Energy and conversion cost: Energy-intensive glass, copper, foil, and resin processes pass higher costs into PCB quotes.
  • Forecasting behavior: Duplicate bookings and excess safety stock amplify constraints, while forecast quality affects allocation.
The shortage of raw materials requires clearer specifications, earlier decisions, and evidence that an alternative is safe.
In practice, a shortage of raw materials should trigger a controlled change review, not an informal purchasing swap.
Standard FR 4 and M6 to M8 Advanced Material Availability
The shortage of raw materials affects standard FR 4 and M6 to M8 class systems differently. FR 4 is a broad performance designation under specifications such as IPC 4101. M6, M7, and M8 are common shorthand for successive MEGTRON low-loss material generations, not interchangeable quality grades.
Standard FR 4 has the widest supplier base. Risk rises with an uncommon prepreg, copper thickness, halogen-free chemistry, high CTI, or a named laminate with no substitution.
M6 supports controlled Dk and low Df. M7 offers still lower loss, while M8 targets 800GbE networking. Panasonic reports Dk 3.08 and Df 0.0012 at 14 GHz for one MEGTRON 8 construction, plus about 30 percent lower loss than MEGTRON 7 at 28 GHz. Ordinary FR 4 would change the channel model.
When a shortage of raw materials affects M6 to M8, compare Dk and Df test conditions, copper roughness, dielectric thickness, resin content, glass weave, Tg, Z-axis expansion, moisture, peel strength, and CAF evidence. Rerun impedance and loss models.
This makes the shortage of raw materials a signal integrity decision as well as a supply decision.
AI Servers Are Driving Demand for High-End Raw Materials
The shortage of raw materials for advanced PCBs is reinforced by the full AI data center architecture, not one accelerator board.
  • Faster channels: 112 Gbps and 224 Gbps class links tighten loss budgets, raising demand for low Df resin, low dielectric glass, and smoother foil.
  • Higher layer counts: Dense routing and power distribution use more laminate and prepreg per board while tightening registration and resin flow control.
  • Larger boards and heavier copper: Server and switching platforms can consume more panel area and copper than ordinary control electronics.
  • More network hardware: Each accelerator deployment expands switch, network interface, optical, and power infrastructure, multiplying the shortage of raw materials across several PCB types.
Nittobo's 2025 integrated report described sharply higher demand for low dielectric glass in AI server switches. The shortage of raw materials may sit inside the laminate, not in the branded name on the drawing.
Raw Material Shortage Trends for 2026 and 2027
The shortage of raw materials through 2027 will likely combine selective tightness with high volatility. Copper may become less constrained, but advanced PCB demand will continue to follow data center construction and network speed transitions.
New copper, foil, glass, and laminate capacity should help gradually, yet qualification will lag. More specialized constructions will make exact core and prepreg combinations harder to replace, and regional lead times will remain uneven.
Assume standard FR 4 remains purchasable while the shortage of raw materials persists for low dielectric glass, HVLP foil, and exact M7 or M8 builds. Review quarterly using quote validity, lead time, allocation, and approved source count.
How Material Shortages Affect Your Production Plan
A shortage of raw materials affects the schedule before fabrication begins, often through engineering change control.
Project impactEarly warningRequired decision
Quote expiresCopper surcharge or price is valid for only daysShorten approval or reserve material separately
Start date slipsCapacity exists, but core or prepreg is unconfirmedMake material ready date a formal milestone
Stackup changesAn equivalent family is offered without construction dataRequire a revised stackup and field solver review
Qualification repeatsDk Df foil profile or resin content changesDefine the minimum validation before approval
Split lots varySeveral lots or sources enter one buildLock traceability and compare coupons by lot
A quoted PCB lead time should start after material confirmation, not merely after purchase order receipt. Otherwise, the shortage of raw materials consumes float intended for fabrication, assembly, and compliance testing.
For milestone planning, record the shortage of raw materials risk separately from factory capacity.
How to Respond to a Shortage of Raw Materials
The most effective response to a shortage of raw materials combines engineering controls with purchasing discipline.
  1. Classify requirements: Mark each material line as performance critical, process critical, customer mandated, or preferred. Do not create a single source without a clear reason.
  2. Freeze the stackup earlier: Confirm actual core, prepreg, copper profile, and pressed thickness before routing is final.
  3. Build an alternate matrix: Record Dk, Df, test method, Tg, Z-axis CTE, resin content, glass style, copper roughness, UL status, and validation. The phrase equivalent material is insufficient.
  4. Reserve by build stage: Cover prototype, validation, and the first production lot without accumulating material that may expire or become obsolete.
  5. Use coupons and first articles: Verify impedance, insertion loss where relevant, microsections, copper thickness, and thermal stress before volume release.
  6. Control every substitution: State no substitution when exact codes are mandatory. Otherwise, require written approval and a revised stackup before manufacturing.
  7. Track leading indicators: Material lead time, quote validity, allocated quantity, approved source count, and requested versus confirmed ship dates reveal a shortage of raw materials before general market news.
Controlled flexibility protects the schedule. An unreviewed alternate can create impedance drift, delamination, via failure, or another qualification cycle.
This process turns a shortage of raw materials from an emergency into a managed engineering change.
How PCBgogo Helps Projects Manage Raw Material Shortages
PCBgogo helps manage a shortage of raw materials by connecting availability to the stackup and to the design constraints that must not change.
  • Material options: PCBgogo supports general FR 4, high Tg, halogen-free, low loss, and selected hybrid builds.
  • Stackup and DFM review: Stackup, impedance, back drill, and panelization review exposes where a material change affects geometry or fabrication margin.
  • Controlled substitution: Customers can state no substitution for mandatory codes. Other alternatives can be reviewed before production.
  • Traceability: Material and production records help distinguish supply changes from process changes.
  • Production continuity: The same approved material logic from prototype through production reduces construction drift.
For a project exposed to the shortage of raw materials, send PCBgogo the stackup, electrical limits, permitted families, forbidden substitutions, forecast, and delivery window. This enables review while engineering choices remain open.
Summary
The 2026 shortage of raw materials is concentrated in copper-related inputs and specialized low-loss systems, while standard FR 4 offers more sourcing flexibility. Projects stay on schedule when teams confirm the construction early, qualify alternates by measured properties, and control substitutions. Share these requirements with PCBgogo before layout release or volume booking.
Will the shortage of raw materials end in 2027?
The shortage of raw materials may ease for copper if disrupted production recovers, but advanced glass cloth, low profile foil, and qualified low loss laminates can remain tight. Plan for selective bottlenecks rather than one end date.
Is standard FR 4 currently hard to obtain?
Common FR 4 constructions are easier to source than advanced low-loss materials. Risk rises with a named grade, uncommon prepreg, special copper weight, halogen-free chemistry, high CTI, or no substitution.
Can M6, M7, and M8 materials replace one another?
No automatic substitution is safe. Their dielectric loss, Dk, copper profile, glass system, and thermal behavior differ, so the stackup and channel model must be reviewed.
What should a PCB material alternate include?
It should include laminate and prepreg codes, Dk and Df with test conditions, glass style, resin content, cured thickness, copper profile, Tg, Z-axis CTE, moisture absorption, UL status, and a validation plan.
When should material be reserved for a PCB build?
Reserve material after the stackup and critical requirements are stable but before the committed fabrication window. For repeat builds, align a rolling forecast with prototype, validation, and production quantities.
How can buyers verify that a shortage is real?
Ask for the unavailable code, missing construction detail, replenishment date, available quantity, quote validity, and proposed alternate. A real shortage of raw materials produces specific constraints that engineering and purchasing can evaluate.
