Types of Resistors for PCB Design and Assembly Guide
182 0 Oct 23.2026, 16:10:00
QUICK ANSWER
 The main types of resistors are fixed, variable, and nonlinear resistors. For most PCBs, start with a fixed chip resistor, then check resistance, tolerance, temperature coefficient, voltage, power derating, pulse energy, noise, package size, and assembly method before approving the BOM.
A resistor that is correct on the schematic can still fail on the PCB if its package runs too hot, its pulse rating is too low, or its construction adds unwanted noise. Understanding the types of resistors therefore matters most when it changes a real design or manufacturing decision.
This guide connects resistor categories with circuit function, PCB layout, sourcing, and assembly so you can select a part that works beyond the nominal ohmic value.
What Is a Resistor
A resistor is a passive two-terminal component that limits current, divides voltage, biases active devices, terminates signals, senses current, and dissipates electrical energy as heat. Its ideal behavior follows Ohm's law, V = I x R, while practical behavior also depends on tolerance, temperature coefficient, rated voltage, parasitic inductance, and long-term stability.
On a PCB, resistance is only the first filter. A 10 kohm, 1% part may be suitable for a pull-up but unsuitable for a low-noise amplifier if its excess noise is high, or for an exposed connector if the transient voltage exceeds its working-voltage rating. Comparing types of resistors by construction reveals these differences before the board reaches validation.
Resistor Symbols and Markings
Resistor symbols identify the electrical function, while markings and reference designators identify the physical part on the PCB. IEC schematics commonly use a rectangle; ANSI-style schematics often use a zigzag. A variable resistor adds an arrow, and a potentiometer shows a third wiper terminal.
The reference designator is normally R followed by a number, such as R17. Through-hole resistors may use color bands, larger SMD parts may use three- or four-digit codes, and very small chip resistors may be unmarked, so the BOM and placement data must remain the controlling records.
Symbol or markingMeaningPCB implication
Rectangle or zigzagFixed resistorMatch value, package, power, and tolerance to the BOM
Resistor plus arrowVariable resistor or rheostatConfirm wiper pin and adjustment access
R plus numberReference designatorKeep schematic, BOM, centroid file, and silkscreen consistent
0 or 000Zero-ohm jumperTreat as a configurable interconnect, not as a true short in every condition
What Resistors Do on a PCB
Resistors control voltage and current at specific nodes, but each function stresses the component differently. That is why the same resistance value can require different types of resistors in different locations.
  • Biasing and pull networks: Pull-up, pull-down, and transistor bias resistors usually carry little power, so tolerance, leakage, standby current, and package availability dominate the choice.
  • Voltage dividers and feedback: Ratio tolerance and temperature tracking can matter more than the absolute tolerance. A matched resistor network can hold gain or sensing accuracy better than two unrelated parts.
  • Current limiting: LED and gate resistors must survive steady current or repetitive charge pulses. Calculate P = I squared x R and check the datasheet derating curve, not only the room-temperature power label.
  • Current sensing: Low-ohmic shunts need a defined temperature coefficient, adequate pulse energy, and Kelvin routing. Four-terminal types of resistors reduce error caused by copper and solder-joint resistance.
  • Signal integrity and protection: Series damping and termination resistors benefit from short return paths and low parasitic inductance. Fusible resistors, thermistors, and varistors handle protection roles that an ordinary chip resistor cannot safely replace.
Once the circuit function is clear, the resistor construction can be chosen for the electrical and environmental stress at that location.
Types of Resistors Used in PCB Design
The three main types of resistors are fixed resistors, variable resistors, and nonlinear or dependent resistors. Each category contains multiple constructions whose accuracy, noise, temperature behavior, pulse endurance, adjustability, and assembly format differ.
Fixed Resistors
Fixed resistors provide a nominal resistance that is not intended to be adjusted in normal use. They are the most common types of resistors on a PCB and include the following constructions.
  • Thick-film chip resistors: These are the default choice for digital pull networks, general biasing, and cost-sensitive designs. They cover tiny SMT packages, but their voltage coefficient and excess noise can be less suitable for precision analog paths.
  • Thin-film chip resistors: Thin-film parts offer tighter tolerance, lower temperature coefficient, and lower noise, making them useful in precision amplifiers, sensor interfaces, and stable dividers.
  • Metal-film leaded resistors: These through-hole parts combine good accuracy, low noise, and stable temperature behavior. They remain practical for prototypes, serviceable equipment, and assemblies where axial parts are acceptable.
  • Metal-oxide resistors: Metal-oxide film tolerates higher temperature and surge stress than many ordinary film parts, which can suit power supplies and snubber positions when the pulse rating is verified.
  • Wirewound resistors: Resistance wire provides high power and strong pulse capability, but the winding can add inductance. Choose non-inductive constructions for high-frequency current sensing or damping.
  • Carbon film and carbon composition resistors: Carbon film is economical for noncritical circuits. Carbon composition can tolerate brief energy pulses but usually has poorer tolerance, noise, and stability, so it is now reserved for specialized pulse applications.
  • Shunt and fusible resistors: Shunts measure current at milliohm-level values, while fusible types are designed to open in a controlled way under specified overloads. Their safety behavior cannot be inferred from resistance and wattage alone.
Variable Resistors
Variable resistors allow resistance or a voltage-divider ratio to be adjusted. The main types of resistors in this category are potentiometers, rheostats, trimmers, and digital potentiometers.
A potentiometer uses three terminals and a wiper to create an adjustable divider; a rheostat uses the wiper and one end terminal to vary series resistance. Trimmers are set during calibration, while panel controls are designed for repeated user operation. Digital potentiometers provide electronic control but have limits on terminal voltage, wiper current, resistance steps, and power that must be checked like any other IC.
Nonlinear and Dependent Resistors
Nonlinear or dependent resistors change resistance in response to temperature, light, or applied voltage. These types of resistors act as sensors or protection components rather than simple fixed loads.
  • Thermistors: NTC thermistors decrease resistance as temperature rises and are used for temperature sensing or inrush limiting. PTC thermistors increase resistance and can provide resettable overcurrent or temperature protection.
  • Photoresistors: Light-dependent resistors change resistance with illumination. They are simple but relatively slow and variable, so photodiodes or phototransistors may suit faster or calibrated sensing.
  • Varistors: Metal-oxide varistors sharply reduce resistance above a voltage threshold and divert transient energy. Their placement, surge rating, degradation behavior, and upstream protection must be considered together.
This category map narrows the field, but final selection still depends on the actual electrical and manufacturing limits of the board.
How to Choose the Right Type of Resistor
Choose among the types of resistors by checking the worst-case circuit stress first, then accuracy, environment, layout, sourcing, and assembly. The following sequence prevents a nominally correct part from becoming the weak point in the PCB.
1. Start with function and resistance range. Identify whether the part is limiting current, setting gain, sensing current, terminating a trace, absorbing a surge, or measuring an environmental variable. This determines which types of resistors are technically plausible.
2. Calculate continuous and transient stress. Use worst-case voltage and current to calculate dissipation, then apply the manufacturer's temperature derating. Check maximum working voltage, overload voltage, pulse duration, repetition rate, and energy separately; a 0.25 W label does not define surge capability.
3. Set the accuracy budget. Combine initial tolerance, temperature coefficient, self-heating, aging, and divider-ratio error. For example, a 100 ppm per degree C resistor can shift 0.5% across a 50 degree C change before other errors are added.
4. Check noise and frequency behavior. Use low-noise thin-film or metal-film types of resistors in sensitive analog nodes. For RF, fast edges, or switching loops, include package parasitics and keep the component close to the node it controls.
5. Select package and layout together. Larger packages generally provide more area for heat spreading and higher voltage spacing, but their pad geometry consumes board space. For shunts, route Kelvin sense traces to the resistor terminals rather than through the high-current copper path.
6. Confirm lifecycle and sourcing. Use an exact manufacturer part number in the BOM when construction matters. If alternates are allowed, define resistance, tolerance, temperature coefficient, rated voltage, power, package, pulse performance, and qualification requirements rather than approving by value alone.
The table below gives a practical starting point; the component datasheet and the board's worst-case analysis still control the final decision.
PCB needPractical starting choiceCritical checks
General pull-up or biasThick-film chip resistorTolerance, leakage, standby current, package
Precision gain or dividerThin-film resistor or matched networkRatio tolerance, temperature coefficient, tracking
High power or pulse loadWirewound, metal-oxide, or pulse-rated thick filmDerating, pulse curve, voltage, heat spreading
Low-ohmic current sensingMetal-element shunt, preferably four-terminalTCR, Kelvin layout, solder and copper resistance
User or factory adjustmentPotentiometer or trimmerCycle life, wiper current, access, sealing
Temperature or surge responseThermistor or varistorResponse curve, energy, aging, protection coordination
Resistor Assembly Methods for SMT and Through Hole
Resistors are assembled by surface mount technology, through-hole technology, or a mixed process that uses both on one PCB. The choice affects board density, thermal behavior, mechanical strength, inspection, rework, and cost.
SMT Resistor Assembly
SMT places chip resistors directly on copper pads using solder paste, automated placement, and reflow. It is efficient for dense layouts and high component counts, but the land pattern, solder volume, component spacing, and thermal balance at both pads must support reliable joints.
For very small types of resistors, unequal heating or solder wetting can lift one end and create a tombstone defect. Keep pad geometry symmetrical, avoid connecting one pad directly to a large copper plane without thermal consideration, and provide clear polarity only for components that actually require it; ordinary resistors are nonpolar.
Through Hole Resistor Assembly
Through-hole resistors place leads through drilled holes and solder them on the opposite side by wave, selective, or hand soldering. Axial and power types of resistors use more board area, yet their leads can offer mechanical support, stand-off from the PCB, and convenient manual replacement.
Define hole diameter, finished lead clearance, bend radius, body stand-off, and lead-trim requirements. Keep hot power resistors away from temperature-sensitive parts and the laminate; raising the body can improve airflow, but it may increase vibration stress unless the component is mechanically supported.
How PCBgogo Supports Both Assembly Methods
A resistor decision is complete only when the selected package can be assembled and inspected consistently. PCBgogo provides one-stop PCB manufacturing and assembly for SMT, through-hole, and mixed-technology boards, so the bare board, component sourcing, placement data, soldering process, and inspection plan can be reviewed as one build.
  • Accurate SMT placement: Advanced Panasonic and Yamaha pick-and-place equipment supports automated placement of chip resistors, including dense passive layouts.
  • Controlled solder deposition: Precision solder paste printing and 3D SPI check paste volume and shape before placement, when printing defects are still easier to correct.
  • Through-hole capability: Wave and manual soldering support axial resistors, power resistors, and mixed assemblies where through-hole parts follow the main SMT process.
  • Inspection coverage: AOI checks visible placement and solder features, while X-ray inspection supports hidden-joint components elsewhere on the same assembly. Resistor values and packages are also checked against the BOM and assembly data.
For quotation and production release, provide the PCB fabrication files, a machine-readable BOM with exact part numbers and packages, and centroid data with side, X and Y coordinates, rotation, and reference designators. Clear alternates and do-not-substitute notes are especially important when different types of resistors share the same resistance value.
Summary
The three main types of resistors are fixed, variable, and nonlinear resistors, but a dependable PCB choice also matches construction, tolerance, temperature coefficient, voltage, continuous power, pulse energy, package, layout, and assembly method. Treat the BOM, land pattern, thermal design, and manufacturing files as part of the electrical decision, not as downstream paperwork.
When a board combines miniature chip resistors with leaded power parts, PCBgogo can manufacture the PCB and assemble the SMT and through-hole components within one coordinated workflow.
What are the three main types of resistors?
The three main types of resistors are fixed, variable, and nonlinear or dependent resistors. Fixed parts hold a nominal value, variable parts allow adjustment, and nonlinear parts change resistance in response to temperature, light, or voltage.
Which resistor type is most common on a PCB
Thick-film chip resistors are the most common general-purpose choice on modern PCBs because they are compact, widely available, and compatible with automated SMT. Precision analog, high-power, surge, RF, and sensing circuits may require other types of resistors.
How do I choose resistor wattage for a PCB
Calculate worst-case continuous dissipation and choose a resistor that remains within its derated limit at the expected ambient temperature. Then check maximum working voltage and pulse or overload curves because wattage alone does not guarantee survival during startup, switching, or surge events.
Are SMT and through-hole resistors electrically different?
They can provide the same resistance, but their construction, parasitics, power dissipation, voltage capability, mechanical behavior, and assembly process can differ. Select the mounting style after comparing the specific datasheets and PCB constraints, not by assuming package style alone determines performance.
Why use a four-terminal current-sense resistor?
A four-terminal current-sense resistor separates the high-current path from the voltage-sense connection. This Kelvin arrangement reduces measurement error caused by copper traces, pads, and solder joints, which can be significant when the target resistance is only a few milliohms.
Can I replace a precision resistor with the same value and tolerance
Not safely without checking the full specification. Two types of resistors with the same value and tolerance may have different temperature coefficients, voltage coefficients, noise, pulse ratings, package dimensions, or qualification status.
