What Is SMT? A Complete Guide to Surface Mount Technology
828 1 Jul 01.2026, 18:03:00
KEY DEFINITION    SMT (Surface Mount Technology) is a PCB assembly method where components are soldered directly onto the surface of a printed circuit board, rather than inserted through drilled holes. An SMT component, also called an SMD, sits on solder paste that is melted in a reflow oven. SMT enables smaller boards, higher component density, and faster automated assembly compared to through-hole methods.
Pull apart an old radio and a modern smartphone, and the difference is obvious. One is full of wires threaded through holes and soldered by hand. The other is a dense grid of components small enough to sit flush on the board surface, placed by machines. That shift is SMT.
This guide covers what SMT is, the components it uses, how the assembly process works, and where it differs from through-hole assembly.
What Is Surface Mount Technology?
Surface Mount Technology is a PCB assembly process where components are mounted and soldered directly onto pads on the board's surface instead of having leads inserted through drilled holes. It replaced through-hole assembly as the dominant manufacturing method starting in the 1980s and now accounts for the vast majority of PCB assembly in consumer, industrial, and automotive electronics.
The core mechanism is straightforward: solder paste holds a component in place on a pad, then heat melts that paste to form a permanent electrical and mechanical bond. Because there is no need to drill holes or bend leads, boards can be populated with far smaller components on tighter spacing. A typical SMT resistor in an 0402 package measures just 1.0mm by 0.5mm, compared to a through-hole resistor that can run 6mm or longer.
SMT vs SMD: What Is the Difference?
SMT is the assembly process; SMD is the component built for that process. The terms are often used interchangeably, but they describe two different things: SMT refers to the manufacturing method, including solder paste application, machine placement, and reflow soldering. SMD refers to the physical component, such as a chip resistor or a QFN package, built with flat contacts instead of wire leads.
TermStands ForWhat It Describes
SMTSurface Mount TechnologyThe assembly process used to mount components on a PCB
SMDSurface Mount DeviceThe component itself, designed for surface mounting
PCBPrinted Circuit BoardThe board that SMDs are mounted onto
 This distinction matters when reading datasheets or ordering parts: a supplier lists a part as an "SMD" while describing the manufacturing line as "SMT assembly."
What Is an SMT Component?
An SMT component is any electronic part with flat metal contacts instead of through-hole leads, built to be soldered directly onto a PCB surface. These fall into a few main categories:
  • Chip resistors and capacitors: Sized in standard packages like 0402 (1.0mm x 0.5mm) or 0603 (1.6mm x 0.8mm), these are the most common SMT components by volume. Placing 01005 components is one of the hardest challenges in SMT assembly, given their near-microscopic size and tight tolerance for misalignment. PCBgogo's advanced SMT assembly service supports 01005 components.
  • Integrated circuits (ICs): Packaged as QFN (Quad Flat No-lead), QFP (Quad Flat Package), or BGA (Ball Grid Array), with pin counts ranging from single digits to several hundred.
  • Diodes and transistors: Typically housed in SOT (Small Outline Transistor) packages for a minimal footprint.
  • Connectors and inductors: Designed with surface-mount tabs or pads instead of the pins used in through-hole connectors.
Because these parts lack long leads, they require precise placement and controlled soldering, which is why SMT assembly relies on automated equipment beyond the prototype stage.
The SMT PCB Assembly Process, Step by Step
SMT PCB assembly follows a consistent sequence regardless of the product. Each stage exists to control a specific failure mode, from misaligned paste to weak solder joints.
1. Solder paste printing. A stainless steel stencil is aligned over the PCB, and solder paste, a mixture of tiny solder particles and flux, is spread across it so paste deposits only on the pads. Too much paste causes bridging between pins; too little causes weak or open joints.
2. Solder paste inspection (SPI). Many production lines use 3D optical systems to check paste height, area, and volume immediately after printing, catching deposition errors before components are placed.
3. Pick-and-place assembly. Automated machines position each SMD onto its paste deposit using vacuum nozzles and camera-guided alignment, placing components with accuracy down to roughly 0.01mm at rates of thousands of parts per hour.
4. Reflow soldering. The populated board passes through a reflow oven with a staged temperature profile, typically peaking around 245°C for lead-free solder, which melts the paste and forms the final connection as the board cools.
Reflow soldering
5. Inspection and testing. Automated Optical Inspection (AOI) scans for missing parts, misalignment, or bridging, while X-ray inspection checks hidden joints under packages like BGAs. Electrical testing then confirms the assembled board performs as designed.
Knowing what each stage of the line is checking for makes it easier to evaluate a fabricator that documents its process at every step, rather than treating it as a black box.
SMT vs Through-Hole Technology
Through-hole technology mounts components by inserting leads through drilled holes and soldering them on the opposite side, while SMT mounts components directly onto the surface pads. Both methods are still used today, often on the same board.
FactorSMTThrough-Hole
Component sizeSmaller, higher densityLarger, more spacing needed
Assembly speedFast, fully automatableSlower, often manual for complex parts
Mechanical strengthLower per jointHigher, better for connectors and heavy parts
Typical useConsumer electronics, high-density boardsPower connectors, components under mechanical stress
ReworkMore difficult on fine-pitch partsEasier to desolder and replace
When to Choose SMT
  • Board space is limited, or component density is high
  • The design targets high-volume, fully automated production
  • Components are fine-pitch ICs, chip resistors, or capacitors
When to Choose Through-Hole
  • The part will face mechanical stress, vibration, or repeated insertion (connectors, switches)
  • A strong solder joint matters more than board space
  • The board needs frequent manual rework or field repair
Many modern boards use both. This mixed configuration, sometimes called Type II assembly, places SMT components for density and through-hole components for parts that need a mechanically robust connection, such as edge connectors.
SMT vs through-hole solder joint cross-section
Common SMT Soldering Defects and How to Prevent Them
Even a well-controlled SMT line produces defects when paste volume, placement accuracy, or reflow temperature drift out of spec. Knowing the common failure modes makes them easier to catch during inspection.
DefectCausePrevention
TombstoningUneven heating lifts one end of a small componentBalance pad thermal mass, control reflow ramp rate
Solder bridgingExcess paste or fine-pitch spacingReduce paste volume, verify stencil aperture design
Cold solder jointsReflow temperature too low or ramp too fastFollow a validated reflow profile for the paste alloy used
Insufficient wettingContaminated pads or expired pasteUse fresh paste, confirm pad finish is within spec
MisalignmentPick-and-place calibration drift or poor fiducial marksCalibrate placement equipment regularly, use clear fiducials
Open jointInsufficient paste deposit or poor pad wettingVerify paste print volume, check pad finish and component coplanarity
VoidingTrapped flux or a poorly designed thermal padUse proper thermal pad stencil design, tune the reflow profile
 According to IPC-A-610, the industry standard for electronic assembly acceptability, solder joints are classified by defect severity across three product classes, giving fabricators a shared benchmark for an acceptable joint versus one requiring rework.
Catching these issues consistently comes down to process discipline. A fabricator that runs SPI and AOI on every board, rather than spot-checking, cuts down on defects that would otherwise surface only after the board reaches a customer. PCBgogo runs SMT assembly lines with SPI, AOI, and X-ray inspection built into the standard process, so boards are checked at each stage rather than only at final QC.
What Affects SMT Assembly Cost?
Two boards with similar dimensions can land at very different price points once assembly is factored in. Cost isn't set by board size alone; it's driven by how much handling, precision, and inspection the components on it require.
Design-related factors
  • Placement count. Every component the pick-and-place machine sets down adds machine time. A board with 800 placements takes noticeably longer to run than one with 150, even on the same panel size.
  • Package complexity. Standard chip resistors and capacitors place quickly with minimal inspection. Fine-pitch ICs, BGAs, and components at the 0201/01005 end of the size range demand tighter placement accuracy and often trigger extra inspection steps, which adds cost per unit.
  • Part variety. Each distinct component on the BOM needs its own feeder slot and setup. A board built from 40 unique parts lines up faster than one using 120 unique parts, even if the total component count is similar.
  • Board sides. Populating both sides means a second paste, place, and reflow pass, plus extra handling in between. Single-sided boards skip that step entirely.
Production-related factors
  • Panel utilization. How efficiently boards are arranged on a panel affects how many units the line produces per run, which spreads fixed costs across more boards.
  • Inspection level. AOI is close to standard on most lines. X-ray adds cost but is often necessary for boards with BGAs or other hidden joints, since there's no other way to verify those connections.
  • Order quantity. Setup, programming, and stencil costs are fixed regardless of quantity, so they get divided across fewer boards on a small prototype run and more boards on a production run. This is the single biggest reason unit cost drops as volume increases.
To see how these interact, take two boards of the same size. One carries 600 common 0603 passives and a couple of SOIC ICs. The other has only 300 components, but several are QFN and BGA packages that need X-ray verification. The second board, despite the lower part count, often costs more to assemble because of the placement precision and inspection it requires.
PCBgogo prices SMT assembly based on these same variables: component count, package type, sides, and inspection level, rather than a flat per-board rate, so the quote reflects what the board actually needs to build correctly.
Why SMT Matters for Modern Electronics
SMT is the reason modern electronics can be small, fast to produce, and dense with functionality at the same time. Without it, the component density inside a smartphone or wearable device would not fit on a board of that size.
The performance benefit compounds the size benefit. Shorter interconnects between SMT components reduce parasitic inductance and capacitance, which matters directly for high-speed and RF designs where signal integrity depends on minimizing trace length.
SMT replaced through-hole assembly as the standard method for building modern circuit boards because it enables smaller components, higher density, and faster automated production. Understanding the process, from solder paste printing through reflow and inspection, makes it easier to specify a board correctly and spot a quality assembly partner.
If you're preparing a design for SMT assembly, PCBgogo supports both prototype and production runs with standard inspection built into every build.
FAQs
What does SMT stand for?
SMT stands for Surface Mount Technology, the PCB assembly method where components are soldered directly onto the board's surface instead of through drilled holes.
Is SMT the same as SMD?
No. SMT is the assembly process, while SMD (Surface Mount Device) refers to the individual component designed to be mounted using that process.
What is the difference between SMT and THT?
SMT mounts components directly onto surface pads, while THT (through-hole technology) inserts component leads through drilled holes and solders them on the opposite side. SMT allows for smaller, denser boards, while THT offers stronger mechanical connections for parts under physical stress.
What temperature is used in SMT reflow soldering?
Lead-free reflow soldering typically peaks around 245°C, following a staged profile that preheats, soaks, and then briefly reaches peak temperature before cooling to avoid thermal damage to components.
Can SMT and through-hole components be used on the same board?
Yes. This is called mixed assembly, and it is common on boards that need SMT density for most components alongside through-hole connectors or parts that require a stronger mechanical joint.
