How to Improve SMT First Pass Yield (FPY) in SMT Processing?
1947 0 Dec 16.2025, 09:12:39
In the highly competitive world of Electronics Manufacturing Services (EMS), there is one metric that fundamentally defines a factory's quality and efficiency: SMT First Pass Yield (FPY).
SMT First Pass Yield (FPY) is an essential key performance indicator (KPI) for any SMT Processing operation. FPY measures the percentage of products that successfully pass all quality tests on the first attempt, without needing any rework or repair. A high FPY directly translates to higher production efficiency, lower costs, and stronger corporate competitiveness.
Understanding the factors that influence this metric is the first step toward continuous improvement. As the saying goes in our industry, "Quality is built, not inspected."
the PCB passes the quality test for the first attempt
FPY vs. Traditional Yield Rate: Understanding the Difference
While FPY is often confused with the general "Yield Rate" (also known as the Acceptance Rate or Good Product Rate), they measure different aspects of quality:
Metric
Definition
Focus
The percentage of products that pass all processes and tests correctly on the first try. Reworked or repaired items are excluded.
Process Quality and Control
The percentage of acceptable products relative to the total processed, including those that have been repaired or reworked.
Final Product Quantity
FPY Calculation Formula:
FPY = (Total Produced Units - (Rework + Repair + Returns))/Total Produced Units * 100%
A low FPY signals inherent flaws in the upstream SMT Processing steps that require immediate attention.
A Comprehensive Plan to Improve SMT First Pass Yield (FPY)
To significantly improve FPY, manufacturers must adopt a holistic strategy focusing on the four critical factors that affect the PCBA Manufacturing line: Man, Machine, Material, and Method. This is often referred to as the 4M approach in quality management.
1. Man (Human Factors)
Human performance is often the root cause of quality deviations.
  • Issues: Inadequate operating skills, poor understanding of SMT Process technology, carelessness, and low responsibility can lead to errors.
  • Improvement Strategy:
  • Training: Provide regular professional training on equipment operation and PCBA Manufacturing process knowledge.
  • Incentives: Establish a robust incentive system to boost employee morale, engagement, and sense of responsibility.
2. Machine (Equipment Factors)
The capability and maintenance of equipment directly impact placement accuracy and soldering quality.
  • Issues: Outdated equipment with low precision (e.g., in a high-density 0201 component environment), or lack of consistent maintenance, leading to frequent breakdowns and line downtime.
  • Upgrade: Replace aging equipment that impacts throughput and accuracy to match modern SMT Processing demands.
  • Maintenance: Implement a rigorous, periodic maintenance schedule to reduce failure rates and ensure equipment runs at peak performance and precision.
3. Material (Raw Material Factors)
The quality of raw materials is non-negotiable for soldering success.
  • Issues: Expired or oxidized electronic components, poor quality solder paste, and improper material management all cause soldering defects.
  • Vendor Audit: Establish a strict supplier evaluation system to ensure only high-quality, traceable materials enter the factory.
  • IQC: Enhance Incoming Quality Control (IQC) procedures to prevent substandard materials from entering the production line.
4. Method (Process Factors)
The design and execution of the manufacturing workflow must be optimized for simplicity and robustness.
  • Issues: Overly complex or poorly designed SMT Process workflows, and inconsistent communication or training following a process change.
  • Optimization: Simplify and refine complex process steps (PCBA Manufacturing process design).
  • Change Management: For any process modification, ensure timely notification, comprehensive training, and continuous monitoring to guarantee a smooth transition and consistent quality.
Conclusion: Partner with PCBGOGO for High FPY
Improving SMT First Pass Yield requires a commitment to continuous improvement across these four critical areas (Man, Machine, Material, Method). By consistently collecting and analyzing production data, manufacturers can identify bottlenecks and implement targeted countermeasures.
Choosing the right EMS partner is essential. PCBGOGO is dedicated to achieving the highest possible SMT First Pass Yield (FPY) through our state-of-the-art facilities and rigorous 4M quality control system. Our focus on precision and efficiency ensures your products are built right the first time.
Contact PCBGOGO today to learn how our optimized SMT Processing lines can minimize rework and maximize the quality and efficiency of your next electronic product!
