Fishing
Interface ICs
7043 0 May 07.2022, 11:22:00
Integrated circuits designed to allow communication between devices.
Interface ICs are integrated circuits that allow to control and manage the communication between two or more devices. They define how the transmission of data is performed depending on the communication protocol used. That is to say, interface ICs are integrated circuits that serve as a link between two systems (or components of a device) that wouldn't be compatible otherwise. The sharing of information between devices is important in electronics, as the applications taking advantage of them are many. For example, they're used in telecommunications, automation and even in audio processing.
