Glass Transition Temperature: How Much Tg Does Your PCB Need?
71 0 Aug 13.2026, 11:38:22
QUICK ANSWER
 Glass transition temperature (Tg) is the point where a PCB laminate softens from a rigid, glass-like state into a rubbery one. Standard FR-4 runs 130 to 140°C, while high-Tg FR-4 starts around 170 to 180°C depending on the fabricator. The rule of thumb: pick a Tg at least 20 to 25°C above your board's highest operating or reflow temperature.
A batch of boards comes back from reflow with hairline cracks radiating out from the plated holes. Nothing changed in the Gerber files, the stencil, or the paste. The laminate did.
Glass transition temperature is the spec behind that kind of failure, and it's also one of the easiest numbers on a datasheet to misread. Here's what Tg actually measures, how much of it a given design needs, and which materials cover the range.
What Glass Transition Temperature Actually Measures
Glass transition temperature marks the point where a PCB laminate's epoxy resin shifts from a rigid, glass-like solid to a softer, rubbery state. Unlike melting, the change happens gradually over a temperature range rather than at one sharp point, and it's reversible: once the board cools back below Tg, the resin returns to roughly its original stiffness.
Fabricators measure Tg using differential scanning calorimetry (DSC) or dynamic mechanical analysis (DMA), both defined under IPC-TM-650. The two methods do not always agree. DMA typically reports a Tg a few degrees higher than DSC for the identical material, which is why the same laminate can show two different Tg figures depending on which datasheet you're reading.
Tg vs. Td: The Two Numbers Engineers Mix Up
Tg and thermal decomposition temperature (Td) sound like they describe the same danger zone, but they measure two different kinds of failure. Tg is reversible: cross it briefly during a normal reflow cycle and the board returns to its original mechanical state once it cools. Td is not. Above Td, the resin itself starts to chemically break down, and that damage doesn't undo itself on the way back to room temperature.
High-Tg FR-4 laminates typically carry a Td in the 340 to 355°C range, comfortably above any reflow or rework temperature a board will see. The practical risk almost never comes from hitting Td. It comes from spending too much cumulative time above Tg across multiple reflow and rework passes, which is what drives the z-axis expansion that eventually cracks a via barrel.
How Much Tg You Actually Need
The right Tg depends less on how hot the finished product gets and more on how much thermal margin the assembly process itself eats up before the board ever reaches its enclosure.
  • Standard consumer electronics operating near room temperature: Standard FR-4 at 130 to 140°C Tg holds up fine for single-pass reflow and normal ambient conditions, and it's the more cost-effective choice when nothing in the design pushes past that.
  • Multilayer or HDI boards with two or more reflow passes: Lead-free reflow peaks around 245 to 260°C, well above standard Tg, on every single pass. A board that only sees one pass shrugs this off; one that goes through reflow twice, gets hand-soldered, then reworked accumulates enough time above Tg that high-Tg material becomes the safer default.
  • Automotive and industrial modules operating in hot enclosures: Apply the 20 to 25°C margin rule directly. A module expected to run at 150°C ambient needs a laminate rated at 170 to 180°C or higher, not just "high-Tg" in the abstract.
  • LED, power supply, and other self-heating boards: The relevant number is the board's own worst-case temperature under load, not the surrounding air, since dense copper and power components generate heat the enclosure alone doesn't reflect.
  • Long-service or mil-spec boards: Years of thermal cycling reward the extra delamination resistance that high-Tg materials carry, even when no single excursion comes close to Tg.
Once a design lands in that high-Tg range, the next question is which specific tier actually covers it.
FR-4 Tg Tiers at a Glance
Fabricators generally group FR-4 into three practical Tg bands, and the label "high-Tg" itself varies a little depending on which fabricator's cutoff you're using, usually starting somewhere between 170 and 180°C.
Tg TierTypical Tg RangeSuggested Max Operating Temp*Common Use
Standard130–140°C~110–115°CConsumer electronics, basic controls
Mid150–160°C~125–135°CCommunication equipment, general industrial
High170–180°C+~145–160°CAutomotive, HDI/multilayer, LED, aerospace
*Based on the 20 to 25°C margin rule described above; confirm against your specific reflow and operating profile.
Signs Your Board Is Already Fighting Its Tg
Some Tg problems only show up after the board has already been built, and they tend to follow the same handful of patterns.
  • Whitish patches or measling near plated holes: early resin-to-glass separation from repeated thermal excursions at or above Tg.
  • Barrel cracking in plated through-holes: once the laminate crosses Tg, its z-axis expansion accelerates well past copper's own expansion rate, and thin-walled or high-aspect-ratio holes crack first.
  • Pad lifting after rework: hand soldering and hot-air rework can hold a small area above Tg far longer than a controlled reflow oven pass does.
  • Warpage across large or thin panels: uneven cooling through the Tg transition locks in bow and twist that wasn't there before assembly.
  • Delamination near dense copper pours or panel edges: heavier copper holds heat longer, which extends time above Tg exactly where the board can least afford it.
None of these show up on an incoming inspection. They show up weeks or months later, which is why matching Tg to the actual thermal load at the design stage is cheaper than troubleshooting it after the fact. That starts with knowing which high-Tg materials are actually available to spec.
High-Tg Materials PCBgogo Runs
PCBgogo keeps three high-Tg FR-4 laminates in regular rotation, and each one covers a slightly different design pressure.
  1. Shengyi S1000-2 (Tg 170 to 180°C DSC, Td 340°C or higher): the general-purpose high-Tg workhorse, built for multilayer boards with heavy inner copper and better through-hole reliability than standard FR-4.
  2. Shengyi S1000-2M (Tg 180°C DSC, 185°C DMA, Td 355°C): a lower z-axis CTE variant of S1000-2. Its own published datasheet shows z-axis expansion holding to about 41 ppm per °C below Tg, then jumping toward 208 ppm per °C above it, roughly a fivefold increase, which is exactly the mechanism behind via barrel cracking on repeated reflow. It's the material to specify on higher layer-count or thick-copper builds where that stress shows up first.
  3. IT180A (Tg 180°C): ITEQ's high-Tg FR4, positioned similarly to S1000-2M. It gives customers a second-source option when a design calls out ITEQ material specifically or when supply flexibility matters more than which brand is on the datasheet.
Engineers can call out any of the three by name on a quote, or describe the board's expected operating and reflow profile and have PCBgogo's engineers confirm the right match during the standard per-order DFM review, before the board goes to fabrication. Start a quote to check pricing and lead time for a specific Tg tier.
Summary
Tg isn't a pass-or-fail number so much as a margin question. Matching it to a board's real thermal load, not just its nameplate operating temperature, is what keeps via barrels intact through years of reflow, rework, and field use. Specify the tier the design actually needs, then confirm it against the fabricator's material list before layout is final.
Is a higher Tg always better for a PCB?
Not necessarily. A higher Tg buys thermal margin, but it doesn't make a board mechanically stronger by itself, and specifying more than a design needs adds cost without changing performance. Match the tier to the board's real operating and reflow profile first.
Does Tg affect signal integrity or dielectric performance?
Tg is a thermal and mechanical spec, not an electrical one, so it doesn't directly set dielectric constant or loss. Some laminates, like S1000-2, combine a high Tg with a low CTE, but high-speed performance is still chosen separately, based on Dk and Df.
Why do DSC and DMA report different Tg values for the same material?
DSC and DMA are both valid IPC-TM-650 test methods, but they measure different physical responses to heat, and DMA typically reports a Tg a few degrees higher than DSC on the identical laminate. Check which method a datasheet used before comparing numbers across two materials.
What Tg does a typical lead-free reflow process require?
Lead-free reflow peaks in roughly the 245 to 260°C range, well above standard FR-4's 130 to 140°C Tg. A single reflow pass rarely causes damage on its own; the risk grows with repeated passes, thick copper, and higher layer counts.
Can a board be reworked without exceeding its Tg?
Bench soldering and hot-air rework can hold a localized area above Tg longer than an automated reflow oven does, since the process is manual and less controlled. Keeping rework passes short and choosing high-Tg material for boards that need frequent rework cuts the risk of pad lifting.
Does high-Tg FR-4 cost more than standard FR-4?
Generally yes, since the resin systems and processing differ, though the exact premium depends on the specific material, layer count, and order volume. Comparing quotes for both tiers on the actual design is more reliable than assuming a fixed markup.
