High-Tg FR4: What It Is, Why It Matters, and When to Specify It
47 0 Jul 08.2026, 17:02:08
If a board has ever come out of reflow warped, or a plated via has cracked after a few thermal cycles, the laminate is usually the first place to look. Standard FR4 has a ceiling on how much heat it can take before it starts to soften, and once a design pushes past that ceiling — through lead-free assembly, dense multilayer stacks, or a hot operating environment — high-Tg FR4 becomes the material of choice.
This guide covers what high-Tg FR4 actually is, how it stacks up against standard FR4, when a design genuinely needs it, and what to check for when sourcing a high Tg PCB from a fabricator.
What Does "Tg" Mean in a PCB Laminate?
Tg stands for glass transition temperature — the point at which the epoxy resin in a laminate shifts from a rigid, glass-like state to a soft, rubbery one. It isn't a melting point; the board doesn't liquefy. But once the resin crosses Tg, its coefficient of thermal expansion (CTE), especially through the Z-axis, increases sharply. That expansion is what stresses copper plating in vias and through-holes, and it's the mechanism behind most heat-related PCB failures.
  • Standard FR4: Tg around 130–140°C
  • Mid-Tg FR4: Tg around 150–160°C
  • High-Tg FR4: Tg of 170°C or higher, with some grades rated at 180°C and above
High-Tg FR4 vs. Standard FR4
PropertyStandard FR4High-Tg FR4
Glass transition temperature (Tg)~130–140°C~170–180°C+
Decomposition temperature (Td)~300°C~340°C
Z-axis CTE below Tg~50–60 ppm/°C~40–50 ppm/°C
Z-axis CTE above Tg~250–300 ppm/°C~200–250 ppm/°C
Moisture absorption~0.15%~0.10–0.12%
Typical cost premiumBaseline10–20% higher
The gap in Z-axis CTE and decomposition temperature is the part that matters most. A laminate that stays dimensionally stable well past reflow temperatures puts far less mechanical stress on plated through-holes, buried vias, and copper traces over the life of the product.
Why High-Tg FR4 Matters for Lead-Free Assembly
Lead-free solder (SAC305) reflows at peak temperatures of roughly 245–260°C, compared with about 183°C for older tin-lead solder. During a typical lead-free reflow profile, the board itself can spend 60–90 seconds above 230°C.
That's already well above the Tg of standard FR4, meaning the laminate is in its rubbery, high-expansion state at exactly the moment solder joints are forming. High-Tg FR4 stays closer to — or still below — its own softening point during that same profile, and its higher decomposition temperature (Td) gives a wider safety margin before the resin itself starts to break down. That combination is a large part of why high-Tg FR4 became the de facto standard once the industry moved to lead-free processes.
Where High-Tg PCB Material Is Actually Needed
Not every board benefits from paying the 10–20% premium for high-Tg FR4. It's most valuable when one or more of these apply:
  • Multilayer boards (6+ layers) that go through multiple reflow or rework cycles
  • Automotive electronics — under-hood ECUs, motor drives, and sensor modules exposed to sustained heat
  • Industrial and power electronics — motor controllers, LED drivers, and power supplies with high thermal loads
  • Outdoor and telecom infrastructure — equipment exposed to wide ambient temperature swings
  • Aerospace, military, and medical devices built to IPC-6012 Class 3, where high-reliability standards effectively require it
  • Large or thin panels (thinner than ~1.0 mm, or larger than roughly 250 × 200 mm) that are prone to warping during reflow
For simple, low-layer-count consumer electronics run through standard lead-free reflow once, mid-Tg FR4 (Tg ≥ 150°C) is often adequate, and standard FR4 may still be fine for tin-lead assembly at room-temperature operation.
Matching Tg to Design Requirements
ApplicationRecommended TgNotes
Consumer electronics, tin-lead assembly≥130°CStandard FR4 is usually sufficient
Consumer electronics, lead-free assembly≥150°CMid-Tg FR4
Automotive, industrial, outdoor, lead-free assembly≥170°CHigh-Tg FR4
Military, aerospace, extreme environments≥180°CHigh-Tg FR4, often paired with IPC Class 3 requirements
What to Check Beyond the Tg Number
Tg alone doesn't tell the full story. When comparing high-Tg FR4 laminates or PCB suppliers, it's worth checking:
  • Decomposition temperature (Td): Look for 340°C or higher for a comfortable lead-free margin.
  • T260/T288 ratings: How many minutes the material withstands 260°C or 288°C before delamination — a useful proxy for real-world solder resistance.
  • CAF resistance: Especially important on fine-pitch designs where via spacing is tight and conductive anodic filament formation is a risk.
  • Moisture absorption: Lower absorption reduces the odds of delamination and measling during thermal stress.
  • Material certification: IPC-4101 slash-sheet compliance and UL recognition matter for regulated industries and for lot traceability.
Manufacturing high-Tg boards also calls for adjusted press cycles (higher lamination temperature, longer dwell time) and tuned drilling parameters, since the harder resin system wears tooling differently than standard FR4. A fabricator that has already validated these process recipes will produce more consistent results than one simply swapping in a different laminate spec sheet.
Common High-Tg FR4 Grades
Laminate suppliers offer a range of high-Tg materials, and the right choice depends on layer count, Td requirements, and whether the design also needs low-loss electrical properties. Commonly specified options include Shengyi S1170 and ITEQ IT-180A for general high-reliability boards, along with equivalent grades from Isola and Nelco for aerospace, medical, or high-Td applications. A fabricator's engineering team can usually recommend the closest available equivalent based on stack-up and reflow requirements.
Is high-Tg FR4 the same as standard FR4?
No. Both are epoxy-glass laminates from the same general family, but high-Tg FR4 uses a resin formulation engineered to raise the glass transition temperature from around 130–140°C to 170°C or higher, along with a higher decomposition temperature and lower Z-axis CTE.
Does every lead-free board need high-Tg FR4?
Not necessarily. A minimum Tg of around 150°C is generally considered adequate for straightforward lead-free reflow. High-Tg FR4 (170°C+) is recommended for multilayer boards, multiple reflow cycles, or harsher operating environments.
How much more does high-Tg FR4 cost?
Typically 10–20% more than standard FR4, though the exact premium depends on the specific grade and the supplier's material sourcing.
What Tg value counts as "high Tg"?
Definitions vary slightly by source: some set the threshold at 170°C, others at 180°C. In practice, anything at or above 170°C is widely marketed and specified as high-Tg FR4.
The Bottom Line
High-Tg FR4 exists because standard FR4 has a real thermal ceiling, and lead-free assembly, denser stack-ups, and hotter operating environments push many designs past it. The material costs somewhat more, but for multilayer boards, automotive and industrial electronics, or anything built to a high-reliability standard, it's a small premium against the cost of warped panels, cracked vias, and field failures. Matching the Tg to the actual thermal profile of the design — rather than defaulting to standard FR4 or over-specifying an extreme-Tg material — is the part that actually determines whether the board holds up over its intended lifetime.
