That NRE Line on Your PCB Quote Isn't a Mystery Fee
27 0 Aug 11.2026, 20:27:12
KEY DEFINITION  NRE, or non-recurring engineering, is a one-time charge covering the engineering and tooling work a PCB manufacturer does before production starts: drill programs, test fixtures, stencils, and file review. It's billed separately from the per-board price and doesn't repeat for reorders, but most design changes trigger it again.
The first time an engineer sees NRE on a PCB quote, the reaction is usually the same: production hasn't even started, so what exactly are we paying for?
The short answer covers everything from drill programs to test fixtures. Here's how it actually breaks down, what changes from prototype to production, and where it tends to go wrong.
What NRE Actually Covers on a PCB Order
NRE covers the one-time engineering and tooling work a manufacturer does to take your design from files to a producible board, not the material or per-unit fabrication cost.
  • Engineering file review and conversion: Before anything gets built, engineers check that your Gerbers, drill files, and stackup line up, often running a DFM (design for manufacturability) pass to catch problems before they hit the shop floor.
  • Drill programs and phototools: Multilayer boards need a separate photofilm layer for each layer of circuitry, plus drill programs written specifically for that design; none of it carries over to a different board.
  • Stencils and test fixtures: Once assembly starts, you need a stencil cut to your exact pad layout and either a flying probe or ICT fixture built to test that specific board.
  • Machine programming and first article setup: Pick and place, reflow, and AOI equipment all need to be programmed with your board's coordinates, and first article inspection criteria get set at this stage too.
Most of that work only has to happen once, but any real design change reopens part of it.
NRE Doesn't Cost the Same at Every Stage of Production
The same PCB design can carry a very different NRE charge depending on whether it's a prototype run, a pilot batch, or full production.
StageWhat NRE Typically CoversHow It Behaves
Prototype (a few to a few dozen boards)File review, drill programs, basic electrical testMakes up the largest share of the unit price
Pilot / low volumeStencil cutting, dedicated test fixtures, first article inspectionUsually billed per batch
Full productionReuses existing programs and tooling, just confirms the revision matchesAmortized across volume until it's nearly negligible
Most manufacturers keep drill programs and stencil files on record, so a reorder of the same design often skips this charge entirely, or gets a reduced rate.
What Design Choices Actually Drive NRE Costs Up
NRE isn't a flat fee. It scales with how complex the design actually is.
  • Layer count and stackup complexity: More layers mean more photofilm layers to align and more drill passes to program, so a multilayer board's NRE typically runs well above a two-layer board's.
  • Board size and panelization: Larger boards or unusual panel layouts make stencil cutting and fixture design harder to standardize.
  • Hole types and process complexity: Blind and buried vias or laser-drilled microvias need extra drill programs and alignment steps, and they're a common line item that pushes NRE higher.
  • Test method: A dedicated ICT fixture costs more upfront than a generic flying probe setup, since it's built specifically for one board.
  • How often the design changes: Any revision touching traces, hole placement, or the stackup can reopen part of the NRE, even on a board already in production.
Knowing which of these actually move the number lets you manage NRE at the design stage instead of getting surprised by the quote.
Where PCBgogo Helps You Avoid Paying NRE Twice
Since design changes are the main reason NRE gets charged more than once, a manufacturer that catches problems before tooling is cut can save you from repeating that cost.
  • Per-order DFM and engineer review: PCBgogo reviews Gerbers and stackup on every order before drill programs and phototools get made, catching design issues before they turn into a rework cycle.
  • AOI and X-ray inspection: Internal misalignment on multilayer boards often doesn't surface until later batches. Catching it early through AOI and X-ray inspection means the tooling built for that design doesn't have to be scrapped and remade.
  • Native file support: PCBgogo accepts Eagle, Altium, and PADS files directly, which cuts down on the re-tooling that comes from format conversion errors.
  • Up to 40 layers with laser-drilled blind and buried vias: For high layer count designs that need blind or buried vias, PCBgogo has the drilling and lamination capability in house, so there's no need to farm that step out to a second supplier.
If you're pricing out a new design, PCBgogo's online quoting tool is a fast way to get engineering feedback alongside the quote itself.
The NRE Mistakes That Cost More Than the Fee Itself
Understanding what NRE covers is only half the problem. Most of the extra cost comes from how teams handle it.
  • Treating NRE as a refundable deposit: NRE pays for engineering hours and tooling that already happened. It doesn't come back after production starts, and assuming otherwise throws off budget planning.
  • Comparing prices without comparing scope: Two quotes can both list "NRE" and cover completely different work; one might include fixture design and the other might not, so the number alone doesn't tell you much.
  • Using a dev board as a stand-in for the real design: A dev board proves the concept works, but it rarely accounts for EMC, testability, or manufacturability, so most of that design work has to be redone anyway.
  • Finalizing the design without talking to the manufacturer: Waiting until the design is locked to get a quote often means rework on drilling or panelization that could have been caught earlier with a DFM pass.
  • Assuming NRE is a one-time event: A component going end-of-life, a new certification requirement, or a customer asking for a new interface can all trigger another design change, and another round of NRE.
Ruling these out ahead of time is what keeps NRE a one-time cost instead of a recurring one.
Is NRE refunded once production starts?
No. NRE pays for engineering review, drill programs, and tooling that's already been completed. It's a one-time cost and doesn't scale down or refund as order volume grows.
Is NRE billed separately from the per-board price?
Usually, yes. NRE typically shows up as its own line item on the quote rather than being folded into the per-unit price, though some manufacturers offer to amortize it into the unit cost instead.
Does a small design tweak trigger NRE again?
It depends on what changed. Adjusting silkscreen text usually doesn't affect NRE, but changes to traces, hole placement, or the stackup usually require reprogramming part of the tooling.
Is prototype NRE the same as production NRE?
No. Prototype NRE usually covers file review and basic programming, while production NRE adds stencils and dedicated test fixtures, so the full production charge is typically more complete.
How can I lower the NRE on a PCB project?
Keeping layer count and process complexity appropriate for the application, limiting unnecessary design revisions, and looping in the manufacturer for a DFM pass early all help keep NRE down.
Can I reuse NRE tooling if I switch manufacturers?
No. Drill programs, stencils, and test fixtures are built around a specific manufacturer's equipment and setup, so switching manufacturers usually means paying NRE again.
NRE isn't a hidden charge. It's the engineering work that has to happen before a design becomes a producible board. Knowing what it covers and which design choices push it higher makes the number on your quote a lot less confusing.
For a specific estimate, PCBgogo's online quoting tool gives you that breakdown along with engineering feedback on the design itself.
