PCB Shop Pricing Guide: How Much Does Custom PCB Manufacturing Cost?
51 0 Jul 09.2026, 19:01:32
If you've started sourcing a custom circuit board, you've probably noticed that PCB pricing isn't a single number — it's a moving target shaped by dozens of small decisions. Two boards that look nearly identical on screen can land at very different price points once you factor in layer count, material, finish, and order quantity.
This guide walks through every major cost driver in PCB fabrication and assembly, gives you realistic price expectations for common project types, and shares practical ways to lower your costs without sacrificing reliability. Whether you're prototyping your first board or planning a production run, understanding these factors will help you read quotes more confidently and avoid paying for specs you don't actually need.
What Determines the Cost of a Custom PCB?
PCB cost isn't set by a flat rate card — it's built up from a combination of material, design complexity, and process choices. Here's how the main variables stack up:
Cost FactorWhy It MattersBudget-Friendly Option
Board size & shapeLarger boards consume more raw material and reduce the number of boards that fit on a production panelUse standard rectangular board shapes whenever possible
Layer countEach additional layer increases lamination, drilling, and plating process stepsUse 2-layer PCBs for simple designs and 4-layer boards for most mixed-signal applications
Base materialStandard FR-4 is much less expensive than high-Tg FR-4, Rogers, or metal-core substratesUse specialty laminates only for RF, high-power, or high-temperature applications
Copper weightHeavy copper (2oz+) requires longer etching and plating cycles, increasing manufacturing costs1oz copper is sufficient for most low-to-medium current designs
Surface finishDifferent finishes such as ENIG, immersion silver, and OSP have different material and processing costsChoose HASL or lead-free HASL for most through-hole and basic SMT applications
Hole size & trace/spaceSmall holes, microvias, and fine trace/space requirements need tighter tolerances and additional fabrication stepsFollow standard design rules unless finer geometries are truly required
QuantitySetup and tooling costs are fixed per order, so higher volumes significantly reduce unit costOrder prototype quantities (5–10 pcs) first to validate the design before full production
Turnaround timeRush production, such as same-day or 24–48 hour service, requires additional resources and higher costsPlan ahead and choose standard lead times whenever possible
Assembly (PCBA)Component sourcing, part count, and SMT/THT assembly requirements directly affect total costReduce unnecessary part variations and select commonly available components
Fabrication vs. Assembly: Two Different Cost Buckets
Bare board fabrication covers the physical board itself: substrate, copper layers, drilling, plating, solder mask, and silkscreen. This is priced primarily by board size, layer count, material, and quantity.
Turnkey PCB assembly (PCBA) adds component sourcing and placement on top of the bare board cost. Assembly pricing depends heavily on the number of unique components (line items), total component count, package types (through-hole vs. surface mount), and whether parts are common and in stock or require special sourcing.
If you're comparing quotes, always check whether a price is for bare boards only or a fully assembled, tested board — this is the single most common source of "why is this quote so different" confusion.
Typical Price Ranges for Common Projects
Exact pricing depends on your specific design, but these rough ranges reflect what hobbyists and engineers commonly see for small prototype batches using standard FR-4 material and lead-free HASL finish:
  • Simple 2-layer board, small size, 5-10 pcs: typically the lowest-cost tier — often just a few dollars per board before shipping
  • Standard 4-layer board, small-to-medium size, 5-10 pcs: moderately priced, reflecting the added lamination and drilling steps
  • 6-layer or higher, or boards with fine trace/space and microvias: priced higher due to tighter tolerances and extra processing
  • Specialty materials (Rogers, aluminum/metal-core, high-Tg, flex/rigid-flex): priced well above standard FR-4 due to material cost alone
  • Assembly adds cost per unique component plus a setup fee, so a board with many different part numbers costs more per unit than one built from a handful of common parts
These figures move up or down quickly with quantity — production runs of 100+ boards often bring the per-unit fabrication cost down substantially compared to a 5-piece prototype batch, since setup and tooling costs are spread across more units. Because so many variables interact, the only reliable way to know your actual cost is to configure your exact specs in an instant online quote tool rather than estimate from general ranges.
Related Reading: Single Layer vs Multilayer PCB: Which One Does Your Project Need?
A Sample Cost Breakdown
To make this concrete, here's how a typical order builds up:
  • Base fabrication cost — driven by size, layer count, and material
  • Surface finish upcharge — if choosing ENIG or immersion silver over HASL
  • Tooling/setup fee — usually a one-time charge per unique design
  • Quantity discount — unit price drops as order size increases
  • Turnaround fee — added if you need expedited production
  • Assembly cost (if applicable) — components plus placement labor, scaled by unique part count and total component count
  • Shipping — varies by weight, destination, and delivery speed
Seeing costs broken out this way makes it much easier to spot where your specific design is adding expense — and where you have room to simplify.
6 Ways to Reduce PCB Costs Without Hurting Quality
  • Stick to standard design rules. Minimum trace/space, standard hole sizes, and common board thicknesses avoid extra processing charges.
  • Choose the right layer count — not more. Extra layers add cost at every step; only add layers your signal integrity or routing density genuinely requires.
  • Match your surface finish to your application. HASL is fine for most through-hole and general SMT boards; save ENIG for fine-pitch components or long shelf-life requirements.
  • Order prototypes before committing to volume. A small validation run catches design issues before they're baked into a large, non-refundable production order.
  • Plan your timeline. Standard turnaround is meaningfully cheaper than rush service — build in lead time wherever your project schedule allows.
  • Simplify your bill of materials. Fewer unique part numbers and more common, readily available components lower both sourcing risk and assembly labor cost.
Why Getting an Accurate Instant Quote Matters
Because so many variables interact — size, layers, material, finish, quantity, and turnaround all move together — generic price lists rarely match what you'll actually pay. The most reliable approach is to enter your exact specifications into a manufacturer's online quoting system and compare real, itemized numbers side by side.
PCBgogo's instant online quote tool lets you input your board specs — dimensions, layer count, material, quantity, and turnaround time — and see a transparent, itemized price immediately, with no back-and-forth email quoting required. For assembly, you can upload your BOM and Gerber files together to get a combined fabrication-plus-assembly quote in one pass, making it easy to see the true landed cost of a finished board before you order.
PCBgogo supports everything from single 2-layer prototypes to complex multilayer, HDI, flex, and rigid-flex boards, with turnkey assembly available for both small prototype batches and production volumes — so you can scale from proof-of-concept to full production with the same manufacturing partner.
Final Thoughts
PCB pricing comes down to a handful of controllable decisions: size, layers, material, finish, quantity, and turnaround. Understanding how each one moves the price lets you make informed trade-offs instead of guessing — and it makes it much easier to spot whether a quote is fair.
The fastest way to know exactly what your board will cost is to run your specs through an instant quote tool rather than relying on general estimates. Upload your Gerber files or design specs to PCBgogo's online quoting system to get a transparent, itemized price for your next prototype or production run.
