PCB Standards: IPC Guide for Manufacturing & Assembly
QUICK ANSWER For a typical rigid PCB, IPC-2221 and IPC-2222 guide the design, IPC-6012 establishes fabrication performance requirements, and IPC-A-600 provides visual acceptance guidance. For assembly, IPC J-STD-001 controls soldering materials and processes, while IPC-A-610 defines electronic assembly acceptability.
PCB standards define how a printed circuit board should be designed, fabricated, inspected, assembled, tested, and documented. They give designers, PCB manufacturers, assembly providers, and buyers a common language for discussing quality.
However, specifying "IPC compliant" on a purchase order is not enough. Different IPC documents govern different stages of production, and IPC Class 1, 2, or 3 must be selected according to the product's reliability requirements.
This guide explains the most important IPC standards for PCB manufacturing, how the three performance classes differ, what to include in a PCB procurement specification, and how to conduct an effective PCB supplier qualification.
What Are PCB Standards?
PCB standards are documented requirements and guidelines covering areas such as:
PCB layout and conductor spacing
Base materials and copper foil
Lamination, drilling, plating, and etching
Annular rings, vias, and hole-wall quality
Solder mask and surface finishes
Dimensional and electrical testing
Soldering process control
Bare-board and assembled-board acceptance
Handling, storage, repair, and traceability
The Five Functions of IPC PCB Standards
One common sourcing mistake is treating every IPC document as an interchangeable quality standard. In practice, IPC standards perform different functions.
| Function | What It Controls | Common Standards |
| Design | Layout, board structure, spacing, documentation, land patterns | IPC-2221, IPC-2222, IPC-2223, IPC-2228, IPC-7352 |
| Materials | Laminates, copper foil, solder mask, surface finish | IPC-4101, IPC-4562, IPC-SM-840, IPC-4552 |
| Performance | How a finished bare board must perform | IPC-6011, IPC-6012, IPC-6013 |
| Acceptance | Target, acceptable, and nonconforming conditions | IPC-A-600, IPC-A-610 |
| Process and testing | Soldering, test methods, handling, rework | IPC J-STD-001, IPC-TM-650, IPC-1602, IPC-7711/21 |
A design standard does not replace a performance specification. Similarly, an acceptance document does not tell a manufacturer how to control every production process. A robust PCB specification connects all five functions.
Key IPC Standards for PCB Design
IPC-2221: Generic Standard on Printed Board Design
IPC-2221 is the general starting point for printed board design. It addresses subjects such as material selection, conductor routing, electrical and mechanical constraints, thermal management, testability, and documentation.
IPC-2222: Rigid PCB Design
IPC-2222 contains design requirements specific to rigid organic printed boards. It supplements IPC-2221 for single-sided, double-sided, and multilayer rigid PCB designs. It is especially relevant when defining:
Layer structures
Via and through-hole construction
Conductor geometry
Board thickness
Mechanical features
Test coupons
IPC-2223: Flex and Rigid-Flex PCB Design
IPC-2223 applies to flexible and rigid-flex printed boards. Flex circuits introduce additional considerations that do not apply to standard rigid PCBs, including:
Bend areas and bend radius
Neutral bend-axis positioning
Coverlay openings
Stiffener transitions
Copper grain direction
Dynamic versus static flexing
Stress concentration near rigid-to-flex transitions
Calling out only IPC-2221 for a rigid-flex design therefore leaves important requirements undefined.
IPC-2228: RF and Microwave PCB Design
IPC-2228 is intended for high-frequency and microwave printed boards. It addresses manufacturability considerations that become important when dielectric properties, conductor geometry, insertion loss, and impedance consistency affect circuit performance.
IPC-7352: Land Pattern Design
IPC-7352 provides current generic guidance for component land-pattern geometry and the formation of reliable solder joints. The older IPC-7351B is still frequently referenced online, but the official revision table identifies it as no longer maintained. IPC-7352 was published in 2023.
This illustrates an important rule: never copy a standard number from an old drawing or article without checking its current status. See the IPC-7352 description
IPC Standards for PCB Manufacturing
IPC-6011: Generic Performance Specification
IPC-6011 provides general performance requirements that apply across printed-board technologies. It works with a sectional performance standard appropriate to the board type.
IPC-6012: Rigid PCB Qualification and Performance
IPC-6012 is one of the most important IPC standards for PCB manufacturing. It establishes qualification and performance requirements for rigid printed boards, including:
Single- and double-sided boards
Multilayer PCBs
Plated through-holes
Blind and buried vias
Microvias
Embedded passive structures
Metal-core constructions
The current revision is IPC-6012F. Application-specific addenda are also available for automotive, space and military, and medical products. The addendum must be compatible with the base standard revision specified in the contract.
IPC-6012 defines product requirements. It should not be confused with IPC-A-600, which visually illustrates acceptance conditions.
IPC-6013: Flexible and Rigid-Flex PCB Performance
IPC-6013 establishes qualification and performance requirements for flexible and rigid-flex printed boards. It covers several constructions, from single-layer flex circuits to multilayer rigid-flex boards.
When sourcing rigid-flex PCBs, a complete specification commonly includes:
IPC-2221 and IPC-2223 for design
IPC-6011 and IPC-6013 for performance
IPC-A-600 for acceptance guidance
Applicable material and test specifications
IPC-A-600: Acceptability of Printed Boards
IPC-A-600 is the widely used visual acceptance standard for bare printed boards. It presents target, acceptable, and nonconforming conditions for externally and internally observable PCB features.
IPC-A-600 may be used to evaluate features such as:
Conductor definition
Solder mask registration
Annular rings
Voids and nodules
Inner-layer registration
Laminate defects
Microsection observations
However, IPC-A-600 is primarily a visual interpretation of requirements contained in performance specifications such as IPC-6012. It should not be used as the only fabrication requirement.
Materials, Solder Mask, and Surface-Finish Standards
Depending on the PCB construction, additional standards may include:
IPC-4101: Base materials for rigid and multilayer printed boards
IPC-4562: Metal foil for printed board applications
IPC-SM-840: Qualification and performance of permanent solder mask and flexible cover materials
IPC-4552: ENIG surface-finish specification
IPC-4555: High-temperature OSP performance specification
IPC-4556: ENEPIG surface-finish specification
IPC-TM-650: Standardized chemical, mechanical, electrical, and environmental test methods
IPC-1602: Printed-board handling and storage
Material specifications should include the applicable IPC-4101 slash sheet or a clearly approved laminate system. Writing only "FR-4" does not define Tg, decomposition temperature, z-axis expansion, loss characteristics, flammability, or CAF performance.
IPC Class 1, Class 2, and Class 3 Explained
IPC performance classes reflect progressively higher expectations for performance, assurance, and inspection.
| IPC Class | General Description | Typical Selection Considerations |
| Class 1 | General electronic products | Function is the primary requirement; limited life and noncritical service may be acceptable |
| Class 2 | Dedicated-service products | Continued performance and extended life are desired, but uninterrupted operation is not critical |
| Class 3 | High-reliability or harsh-environment products | Performance on demand is critical, downtime cannot be tolerated, or failure could create significant risk |
The official IPC guidance emphasizes that the customer is responsible for specifying the required class. It also notes that an assembled board cannot achieve a higher class than its underlying bare PCB. See the IPC performance-class guidance
Does Every Medical, Automotive, or Aerospace PCB Require Class 3?
No. Product category alone does not determine IPC class.
A noncritical medical accessory, an infotainment controller, and a flight-control system can have very different reliability requirements even though they fall within regulated industries. The correct class should be selected through product risk analysis, customer requirements, regulatory expectations, and intended operating conditions.
Application-specific addenda may also be required. Class 3 by itself does not automatically satisfy every automotive, medical, aerospace, defense, or space requirement.
Why Not Specify Class 3 for Every PCB?
Class 3 can require tighter acceptance limits, more process control, additional inspection, more extensive documentation, and higher manufacturing capability. These requirements can affect:
PCB price
Fabrication lead time
Available supplier pool
Inspection cost
Manufacturing yield
Documentation burden
Specify Class 3 when the product risk justifies it, not simply because it sounds superior.
IPC Standards for PCB Assembly
The two most important documents for PCB assembly are IPC J-STD-001 and IPC-A-610.
IPC J-STD-001: Soldering Process Requirements
IPC J-STD-001 defines materials, methods, process controls, and verification requirements for producing soldered electrical and electronic assemblies. It applies to leaded and lead-free soldering processes.
IPC-A-610: Electronic Assembly Acceptance
IPC-A-610 defines acceptability criteria for completed electronic assemblies. It is commonly used by production inspectors and quality teams to evaluate component installation, solder joints, cleanliness, coating, and assembly workmanship.
A simple way to remember the difference is:
J-STD-001: How a controlled soldering process should produce the assembly
IPC-A-610: How the completed assembly is evaluated
Additional assembly documents may include:
IPC-7525 for stencil design
IPC-7093 for bottom-termination components
IPC-7095 for BGA design and assembly
IPC-7711/21 for rework, modification, and repair
IPC/WHMA-A-620 for cable and wire-harness assemblies
J-STD-002 and J-STD-003 for solderability testing
If a product requires an automotive or space addendum, specify the matching revision rather than adding an unrelated or outdated document.
PCB Supplier Qualification Checklist
Effective PCB supplier qualification verifies whether a manufacturer can repeatedly build the specific technology you need. A quality certificate alone is not sufficient.
1. Verify the Quality Management System
Request and validate applicable certificates, which may include:
ISO 9001
IATF 16949 for automotive work
ISO 13485 for medical-device supply chains
AS9100 for aerospace applications
UL recognition for applicable PCB constructions
Confirm the certificate scope, manufacturing address, issuing body, expiration date, and whether the quoted factory is included.
2. Match Capability to the Actual Design
Compare the design with the supplier's demonstrated production capability:
Layer count and board thickness
Minimum trace and spacing
Minimum mechanical and laser-drilled hole size
Aspect ratio
Blind, buried, stacked, and staggered vias
Via-in-pad and copper-filled microvias
Flex and rigid-flex construction
Controlled impedance
High-frequency or low-loss materials
Heavy copper
Surface finishes
Tolerance and registration capability
Do not qualify a factory only from its advertised maximum values. Ask for normal production capability and proven yield on similar builds.
3. Audit Process Control
A process audit should review controls for:
Incoming material verification
Storage and shelf-life management
Inner-layer imaging and AOI
Lamination recipes and press control
Drilling and desmear
Electroless copper and electrolytic plating
Etching and conductor-width control
Solder-mask application
Surface finishing
Routing and dimensional inspection
Final cleaning, packaging, and storage
For each critical process, check whether parameters are documented, monitored, traceable, and supported by corrective-action procedures.
4. Review Inspection and Test Capability
Depending on product risk, request evidence of:
Automated optical inspection
Automated visual inspection
Flying-probe or fixture electrical testing
Microsection analysis
Plating-thickness measurement
Impedance coupon testing
Ionic cleanliness testing
Solderability testing
Thermal-stress or reflow-simulation testing
X-ray inspection for hidden assembly joints
Functional or in-circuit testing for PCBAs
The requirement is not simply that equipment exists. Verify calibration, operator training, sampling plans, acceptance limits, and record retention.
5. Check Traceability and Change Control
A qualified supplier should be able to trace a shipment to relevant production information, such as:
Material manufacturer and lot
Production traveler
Process dates
Inspection and test records
Nonconformance and rework history
Final acceptance status
The supply agreement should also define when the customer must be notified about material, process, equipment, production-location, or sub-supplier changes.
6. Run a Pilot Lot
Before approving high-volume production, place a representative pilot order and evaluate:
DFM communication quality
Engineering-question response time
Conformance to drawing notes
Dimensional results
Electrical-test performance
Microsection results where applicable
Impedance data
Documentation completeness
Packaging and delivery
Assembly yield
A supplier that passes a document audit can still fail to execute consistently. Pilot-lot performance provides direct evidence.
7. Maintain a Supplier Scorecard
| Category | Suggested Weight |
| Technical capability | 20% |
| Process control | 20% |
| Inspection and testing | 20% |
| Traceability and change control | 15% |
| Quality-system maturity | 10% |
| Pilot and production quality | 10% |
| Communication and delivery | 5% |
Safety-critical requirements should be treated as pass/fail gates rather than averaged into a score.
Common PCB Standards Mistakes
Using "IPC compliant" without a standard number
IPC publishes hundreds of standards. The statement does not identify the applicable document, class, revision, or exceptions.
Using IPC-A-600 as the only manufacturing specification
IPC-A-600 helps inspectors interpret visible conditions. IPC-6012 or another appropriate performance specification should define the rigid board's fabrication requirements.
Confusing PCB and PCBA standards
IPC-A-600 applies to bare printed boards. IPC-A-610 applies to populated and soldered electronic assemblies.
Copying outdated standards
Some frequently quoted documents have been replaced, superseded, or are no longer maintained. For example, IPC-1601 has been superseded by IPC-1602, while IPC-7352 provides current land-pattern guidance.
Assuming ISO 9001 defines product acceptance
ISO 9001 evaluates the quality management system. It does not replace PCB design rules, performance requirements, workmanship criteria, or customer drawings.
Assuming an employee certificate qualifies the entire factory
IPC training credentials can demonstrate personnel knowledge, but they do not automatically prove that every factory process, product, or production lot complies with a specified standard.
Working With PCBgogo
At PCBgogo, we turn your PCB designs into production-ready boards through quick-turn PCB fabrication, turnkey PCB assembly, component sourcing, and professional engineering file review.
Our manufacturing and quality-control capabilities include automated optical inspection (AOI), X-ray inspection, electrical testing, and controlled-impedance verification. We support rigid, flex, rigid-flex, HDI, and multilayer PCBs for applications ranging from rapid prototyping to volume production.
Our quality management systems and manufacturing processes are supported by certifications and credentials including ISO 9001, IATF 16949, ISO 13485, and UL. You can review our PCB manufacturing capabilities to determine whether they match your board specifications.
For a new project, you can:
What are the most important IPC PCB standards?
For rigid PCBs, the most frequently used documents include IPC-2221 and IPC-2222 for design, IPC-6011 and IPC-6012 for performance, and IPC-A-600 for bare-board acceptance. The exact combination depends on the board technology and application.
What is the main IPC standard for PCB assembly?
IPC J-STD-001 establishes soldering process requirements, while IPC-A-610 defines acceptance criteria for completed electronic assemblies. They are commonly used together.
What is the difference between IPC-A-600 and IPC-A-610?
IPC-A-600 covers the acceptability of bare printed boards. IPC-A-610 covers populated and soldered electronic assemblies.
Is IPC Class 3 always better than Class 2?
Class 3 provides a higher level of assurance for critical applications, but it can increase cost, inspection, lead time, and supplier constraints. The correct class should be selected through risk and application analysis.
Does ISO 9001 replace IPC standards for PCB manufacturing?
No. ISO 9001 addresses the supplier's quality management system. IPC standards define PCB-specific design, manufacturing, performance, process, and acceptance requirements.
How do I verify a PCB supplier's IPC compliance?
Specify the exact standards and revisions, audit production and inspection controls, review personnel competence, run a representative pilot lot, and request objective quality records. A general "IPC compliant" statement is not enough.
